Partition size OS for installation
  • raul.recinosm
    • Jun 2018
    Hello, i need install zabbix for monitor over 150 networks device like cisco router, switch and other device over snmp, the IT team ask for the specific size for partitions of etc, var, usr and / this for ubuntu server.
    Thanks for your help.
  • LenR
    • Sep 2009
    • 1010
    I'm RHEL, but / used 14G (make it 20G for free space). I don't separate /etc or anything but /boot and /var/lib/mysql. The size of the database will depend on your volume, but yon can probably start with 20G. Use LVM, it will grow on you :-)
    • kernbug
      • Feb 2013
      • 329
      Hi
      /boot - no LVM, just 512MB, ext4
      / - LVM, start with 10G, ext4
      /var - LVM, start with 10G, ext4
      /var/lib/mysql - LVM, perfectly - separate LUN if VM or SAN/DAS, 100G, xfs (exact size may differ for your needs to store history/trends)
      /mnt/backup - LVM, 200G, xfs (you need place to make backups, rotate them and prepare)
      • raul.recinosm
        • Jun 2018
        thanks to all, my server is in production, i use 20Gb for OS and 500Gb por mysql.
        Regards
