Trigger checking for returned string - Web Scenario
  • lpossamai
    • Jun 2018
    • 119
    Hi all,
    I've got a Zabbix Server 3.4 with a Web Scenario setup. The Web scenario looks like:
    Headers:
    Content-Type => text/xml
    Required string => "APIcheckTest1" status="up"
    Required status codes => 200
    URL: https://api.example.com/Ping/1.1
    That works fine and I have created a trigger like:
    {webserver.example.com:web.test.rspcode[API_example.com,API - APIcheckTest1].[B]min([/B]5m[B])[/B]}<>200
    however, I also need another trigger for the Required string. If the required string returns anything but ("APIcheckTest1" status="up"), then triggers an alert.
    Already tried this thread but it does not work for me.
    Any tips?
    Thanks in advance!
  • kernbug
    • Feb 2013
    • 329
    Originally posted by lpossamai
    Hi all,
    Headers:
    Any tips?
    Thanks in advance!
    Hello
    I think '.regex' time for web monitoring: https://www.zabbix.com/documentation...ar_expressions
    Search string: (status)(=)("up") or this one ((?:[a-z][a-z]+))(.)(("up").
    • lpossamai
      • Jun 2018
      • 119
      Originally posted by kernbug
      Hello
      Do you mean "web.page.regexp[]"?
      So it would be something like???
      {webserver.example.com:web.page.regexp[https://api.example.com,/Ping/1.1,443,(status)(=)("up")]}
      Cheers!
      EDIT 1:
      Tried to simulate that and I get an error from the Zabbix Server:
      zabbix_get -s webserver.example.com -k "web.page.regexp[api.example.com,/Ping/1.1,443,(status)(=)("up"),10]"
      ZBX_NOTSUPPORTED: HTTP get error: cannot connect to [[webserver.example.com]:443]: [4] Interrupted system call
      • kernbug
        • Feb 2013
        • 329
        Hello
        Hello
        In your example: webserver.example.com - whose is this address?
        • lpossamai
          lpossamai commented
          That is same server as api.example.com.. sorry my mistake.
      • kernbug
        • Feb 2013
        • 329
        Do you have Zabbix Agent on this web server?
        • lpossamai
          lpossamai commented
          yes... i do!
      • lpossamai
        • Jun 2018
        • 119
        Does anyone have any tips here? Still trying to figure this out....
        Cheers!
        • lpossamai
          • Jun 2018
          • 119
          UPDATE:
          test.xml:
          <?xml version="1.0" encoding="UTF-8"?><ping><service name="APITest1" status="up"/><service name="APIcheck1" status="down"/></ping>
          Tried with (from the webserver itself):
          zabbix_agentd -t 'web.page.regexp[localhost,test.xml,80,\"APITest1\"]'
          Returns: [s|"APITest1"]
          zabbix_agentd -t 'web.page.regexp[localhost,test.xml,80,/"APITest1" status="up"\/>/]'
          Returns: web.page.regexp[localhost,test.xml,80,/"APITest1" status="up"\/>/] [s|]
          • kernbug
            • Feb 2013
            • 329
             zabbix_agentd -t 'web.page.regexp[localhost,test.xml,80,[COLOR=#FF0000]\"APITest1\"[/COLOR]]' Returns: [s|"APITest1"]
            Yep, correct.
            <?xml version="1.0" encoding="UTF-8"?><ping><service name="APITest1" status="up"/><service name[COLOR=#FF0000]="A[/COLOR]PIcheck1" [COLOR=#FF0000]status="down"[/COLOR]/></ping>
            zabbix_agentd -t 'web.page.regexp[localhost,test.xml,80,[COLOR=#FF0000]/"[/COLOR]APITest1[COLOR=#FF0000]"[/COLOR] status=[COLOR=#FF0000]"up"[/COLOR]\/>/]'
            Highlighted in red, if you are trying to find exact string, specify exact string to find
            Also tested on my test setup:
            [root@z34t]# zabbix_agentd -t 'web.page.regexp[www.apache.org,/foundation/how-it-works.html,80,[COLOR=#008000]themselves the "Apache Group"[/COLOR]]'
            web.page.regexp[www.apache.org,/foundation/how-it-works.html,80,themselves the "Apache Group"] [COLOR=#0000FF][s|themselves the "Apache Group"][/COLOR]
            [root@z34t]# zabbix_agentd -t 'web.page.regexp[www.apache.org,/foundation/how-it-works.html,80,[COLOR=#008000]themselves the "[/COLOR][COLOR=#FF0000]_[/COLOR][COLOR=#008000]Apache Group[/COLOR]"]'
            web.page.regexp[www.apache.org,/foundation/how-it-works.html,80,themselves the "_Apache Group"] [COLOR=#0000FF][s|][/COLOR]
            • Semiadmin
              • Oct 2014
              • 1626
              Hi, lpossamai
              Try a trigger like this one:
              {webserver.example.com:web.test.error[API_example.com,API - APIcheckTest1].regexp("required pattern")}=1 and {webserver.example.com:web.test.fail[API_example.com,API - APIcheckTest1].last()}>0
              • lpossamai
                • Jun 2018
                • 119
                Yep, correct.
                umm... so how can I know if it is the correct regexp? When it returns this?
                [B][root@zabbix ~]# [/B]zabbix_agentd -t 'web.page.regexp[api.example.com,/Ping/1.1,443,\"APITest1\" status="up"]'
                web.page.regexp[api.example.com,/Ping/1.1,443,\"APITest1\" status="up"] [s|]
                If that is correct and the expression is
                , then on my Web Monitoring scenario where should I put it? In the "Required string" field?
                • lpossamai
                  • Jun 2018
                  • 119
                  Originally posted by Semiadmin
                  Hi, lpossamai
                  Thanks but I first need to find out the correct regexp for it.
                  • Semiadmin
                    • Oct 2014
                    • 1626
                    regexp("required pattern") is your regexp, because there is this text in "Last error message of scenario ..." item if required string not found:
                    required pattern "APIcheckTest1" status="up" was not found on ....
                    • lpossamai
                      • Jun 2018
                      • 119
                      okay.. got it...
                      The expression is:
                       [TABLE]
                      [TR]
                      [TD]\"APITest1\" status="up"[/TD]
                       		[/TR]
                      [/TABLE]
                      I changed my test.xml to status="down" and it is working. It is giving me an error that could not find the string.
                      Now I need to figure out the trigger.
                      • lpossamai
                        • Jun 2018
                        • 119
                        Hi, lpossamai
                        I managed to get the trigger working like this:
                        {webserver.example.com:web.test.error[Scenario].strlen()}>0 and {webserver.example.com:web.test.fail[Scenario].last()}>0
                        Reference: https://www.zabbix.com/documentation...nitoring/items
                        Thanks guys for the help!
                        • lpossamai
                          • Jun 2018
                          • 119
                          #15
                          Is there a way to get the Web Scenario Step name on the trigger?
                          I.e: Failed step {STEP.NAME} on host {HOST.NAME}
                          Assuming by https://www.zabbix.com/forum/zabbix-...rigger-message this feature has not been implemented yet? Does anyone have a workaround this?
                          Cheers!
