Recovery Operations does not execute remote commands
  • Mameli
    • Jun 2018
    I want to use an Action to open and close ITSM incidents.
    Both Operations and Recovery Operations run remote scripts.
    When a trigger is ON, the Operations set in the action is runned correctly.
    But, when the problem is resolved, the Recovery Operations is not executed.
    I need to know how Recovery Operations works.
    Thank you.
  • kernbug
    • Feb 2013
    • 329
    Thank you.
    Hi
    Official docs about operations recovery https://www.zabbix.com/documentation...ery_operations
    Can you run recovery operations script from user zabbix on the Zabbix Server? Also you need to check logs from Zabbix Server.
