Some problem with zabbix need to resolve
  • kenny.dang
    • Jul 2018
    Dear
    After few hour learn about zabbix i had some question need to answer,
    - My company have 250 computer use win 10 so i want to use zabbix manager all computer's information ( hardware and software ) zabbix can do it ?
    - when i down zabbix agent and extract the folder bin\win64 have 3 file ( zabbix-agent , zabbix-get , zabbix-sender ) what's difference bettwen 3 file ? and when i install on computer win 10 what file i should install
    - And do you have guide how to install zabbix server and install on computer to manager
  • LenR
    • Sep 2009
    • 1010
    The zabbix server must be Linux, there are instructions in the manual or you might be able to use a VM appliance.
    Zabbix agent runs on a client computer to gather stats. Sender can be used in scripts to send data so you won't need it to get started. Get is used mostly for testing to get a single value from the agent.
    • Linwood
      • Dec 2013
      • 398
      I think it is worth asking what you mean by "Manage all computers information (hardware and software)".
      Zabbix can help with inventory, e.g. what OS version you are running, and with some custom work it might also deal with things like what versions of anti-virus are loaded (etc.). But it is not a very complete configuration management tool for windows. It is mostly aimed at managing events -- running out of disk, CPU's too busy, etc. It is also a (mostly) one-way configuration management tool when used that way at all -- a real configuration management tool for windows should also allow you to distribute software, adjust settings, configure user settings and policy,e tc.
      Before you head too far down the path, itemize your needs and see if you see it in the zabbix box.
