Help creating a Trigger for Hard Drive Space.
  • jfha73
    • Aug 2018
    • 33
    Hey guys,
    I just created an Item for Filesystems checking for the space on partitions, using the Key vfs.fs.size[fs,pfree].
    Now I want to create a trigger for this Item that will show as Warning at 10% and as Critical at 5%, how can I do that?
    Thanks.
  • pransakti
    • Jul 2018
    did some template already define some trigger for HDD ?
    {Template Net Mikrotik SNMPv2:vfs.fs.pused[hrStorageSize.{#SNMPINDEX}].avg(5m)}>{$STORAGE_UTIL_WARN}
    {Template Net Mikrotik SNMPv2:vfs.fs.pused[hrStorageSize.{#SNMPINDEX}].avg(5m)}>{$STORAGE_UTIL_CRIT}
    with value in %
    <macro>
    <macro>{$STORAGE_UTIL_CRIT}</macro>
    <value>90</value>
    </macro>
    <macro>
    <macro>{$STORAGE_UTIL_WARN}</macro>
    <value>80</value>
    </macro>
    • jasbinschek
      • Dec 2017
      • 19
      with value in %
      <macro>
      <value>90</value>
      </macro>
      <macro>
      <value>80</value>
      </macro>
      i would do this on the first trigger:
      {Template Net Mikrotik SNMPv2:vfs.fs.pused[hrStorageSize.{#SNMPINDEX}].avg(5m)}>{$STORAGE_UTIL_WARN} && {Template Net Mikrotik SNMPv2:vfs.fs.pused[hrStorageSize.{#SNMPINDEX}].avg(5m)}<{$STORAGE_UTIL_CRIT}
      so you wouldn't get 2 alarms when your item gets 90%+
      also, the correct threshold would be 90 and 95, so:
      <macro>
      <value>95</value>
      </macro>
      <macro>
      <value>90</value>
      </macro>
      • rbatton
        • Nov 2018
        Apologies but VERY NEW to Zabbix and I am hunting for exactly this. As I can find the Trigger prototypes for the trigger, I do not find where you set the "macro" for this so the values for $STORAGE_UTIL_CRIT and $STORAGE_UTIL_WARN can be changed? It's probably glaringly obvious but I am not finding this.
        • MattK
          • Jul 2021
          • 15
          For anyone still having trouble finding where to edit these values:
Name:	Screenshot 2021-08-03 094515.png
