trigger.get filter
  • AlBoPo
    • Aug 2018
    • 23
    trigger.get filter
    I want to use `trigger.get` API and I'd like to add a filter to the request to only retrieve triggers I'm interested in.
    So if I look at the [doc](https://www.zabbix.com/documentation.../trigger/get?s[]=trigger&s[]=get), it's said:
    <Accepts an array, where the keys are property names, and the values are either a single value or an array of values to match against.>
    But what a property name is exactly?
    I'd like to filter the results on an existing trigger tag. Is it possible?
    I tried the following query but it doesn't seem to use my filter:
    { "jsonrpc": "2.0", "method": "trigger.get", "params": { "output": [ "triggerid", "description", "priority" ], "selectTags" : "extend", "filter": { "tags": [ "tag": "device" ] }, "sortfield": "priority", "sortorder": "DESC" } }
