SNMPTrap message can't display on zabbix gui
  • lxh9090
    • Aug 2018
    1、/etc/zabbix/zabbix_proxy.conf
    StartSNMPTrapper=1
    SNMPTrapperFile=/var/log/zabbix/zabbix_traps.log
    2、/etc/snmp/snmptrapd.conf
    disableAuthorization yes
    perl do "/usr/bin/zabbix_trap_receiver.pl"
    3、/var/log/zabbix/zabbix_traps.log
    14:48:47 2018/08/28 ZBXTRAP 10.81.0.3
    PDU INFO:
    notificationtype TRAP
    version 0
    receivedfrom UDP: [10.81.0.3]:64332->[10.22.16.77]:162
    errorstatus 0
    messageid 0
    community public
    transactionid 548
    errorindex 0
    requestid 0
    VARBINDS:
    DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (2159745587) 249 days, 23:17:35.87
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.9.9.41.2.0.1
    SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.2.253936 type=4 value=STRING: "CDP"
    SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.3.253936 type=2 value=INTEGER: 5
    SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.4.253936 type=4 value=STRING: "NATIVE_VLAN_MISMATCH"
    SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.5.253936 type=4 value=STRING: "Native VLAN mismatch discovered on GigabitEthernet1/22 (1), with JSDS-BG-2960-3 FastEthernet0/34 (15)."
    SNMPv2-SMI::enterprises.9.9.41.1.2.3.1.6.253936 type=67 value=Timeticks: (2159745587) 249 days, 23:17:35.87
    SNMP-COMMUNITY-MIB::snmpTrapAddress.0 type=64 value=IpAddress: 10.81.0.3
    SNMP-COMMUNITY-MIB::snmpTrapCommunity.0 type=4 value=STRING: "public"
    SNMPv2-MIB::snmpTrapEnterprise.0 type=6 value=OID: SNMPv2-SMI::enterprises.9.9.41.2
    trapperfile can receive snmptrap message but can't display on zabbix gui
  • lxh9090
    • Aug 2018
    • m_d_c13
      • Jan 2018
      • 23
      Check in your zabbix_trap_receiver.pl file where is trapper file. It must be:
      $SNMPTrapperFile = '/var/log/zabbix/zabbix_traps.log';
      • lxh9090
        • Aug 2018
        Of course, otherwise trapperfile will not receive the log.
        • lxh9090
          • Aug 2018
          Do you have any better suggestions about this problem?
          • PDMM
            • Mar 2017
            I do not understand the language i see in the image.
            Do you create an item where you store the traps? Of the text type?
            The key seems right to me, it must be of the snmptrap.fallback type
            I hope to be helpful.
            regards
            En Español:
            No entiendo el idioma que se ve en la imagen.
            Usted creo un item donde almacena los traps ? Del tipo texto?
            El key me parece correcto, debe ser del tipo snmptrap.fallback
            Espero sea de ayuda.
            Saludos
            • m_d_c13
              • Jan 2018
              • 23
              Check in your zabbix_server.log for error messages about traps. Maybe for some reason zabbix discard traps
              • lxh9090
                • Aug 2018
                The most troublesome problem is that you can hardly see any problems from the log. zabbix_proxy.log
                • m_d_c13
                  • Jan 2018
                  • 23
                  In this case I have no idea where the problem is. Why don't you try with snmptt
                  • lxh9090
                    • Aug 2018
                    Ok, that's still thanks.
