ICMP monitoring with map events
  • carlos_souza
    • Mar 2014
    • 27
    #16
    Originally posted by aib
    Could you tell a little bit more about ICMP pings?
    Could you change DebugLevel=4 and give some information from zabbix_server.log file where we can read about errors with ICMP/fping correlated?
    For sure, aib!
    But the log file is so big... I'll post only the error about fping, ok?
    At the beginning of the file the predominant erorr is :
    6555:20140228:200036.915 fping failed: "/usr/sbin/fping6: can't create raw socket (must run as root?) : Operation not permitted."
    At the end of the file, the predominant error is:
    2152:20140306:175003.411 At least one of '/usr/sbin/fping' , '/usr/sbin/fping6/' must exist. Both are missing in the system.
    • aib
      • Jan 2014
      • 1615
      #17
      try to cheat the system.
      1) copy fping & fping6 in new location
      # cp /usr/sbin/fping* /sbin
      2) change the settings in zabbix_server.conf
      - uncomment lines
      # FpingLocation=/usr/sbin/fping
      # Fping6Location=/usr/sbin/fping6
      - change the path to correct one
      FpingLocation=/sbin/fping
      Fping6Location=/sbin/fping6
      3) To be completely protected, repeat the same set of commands as before:
      # chown root:zabbix /sbin/fping
      # chown root:zabbix /sbin/fping6
      # chmod 710 /sbin/fping
      # chmod 710 /sbin/fping6
      # chmod ug+s /sbin/fping
      # chmod ug+s /sbin/fping6
      # chmod +s /sbin/fping
      # chmod +s /sbin/fping6
      4) Add some settings in /etc/sudousers
      zabbix ALL=(root) NOPASSWD: /sbin/fping
      zabbix ALL=(root) NOPASSWD: /sbin/fping6
      5) restart zabbix_server and check the errors :
      #/etc/init.d/zabbix-server restart
      # grep -i fping /var/log/zabbix/zabbix_server.log
      6) Show us the result.
      Does it sound like a plan?
      Sincerely yours,
      Aleksey
      • carlos_souza
        • Mar 2014
        • 27
        #18
        Thanks for the idea, aib! But the problem still the same...
        2152:20140306:175003.411 At least one of '/sbin/fping' , '/sbin/fping6/' must exist. Both are missing in the system.
        I'll try to reinstall zabbix... but thanks!
        • aib
          • Jan 2014
          • 1615
          #19
          Did you escaped from the second message ?
          Also I find the notes that - sometimes - it happens when user zabbix not in group zabbix.
          Try this command
          # usermod -a -G zabbix zabbix
          and restart zabbix_server.
          OK?
          Sincerely yours,
          Aleksey
          • carlos_souza
            • Mar 2014
            • 27
            #20
            This message erros stoped to appear to me. But I still not have permission.
            I'll try to reinstall zabbix with the vmdk. Thanks.
            • aib
              • Jan 2014
              • 1615
              #21
              Did you try my last command which add zabbix user in zabbix group?
              Sincerely yours,
              Aleksey
              • carlos_souza
                • Mar 2014
                • 27
                #22
                Try this command
                OK?
                Man, I reinstalled zabbix and tried the command
                #usermod -a -G zabbix zabbix
                AND IT HAS FUNCTIONED!!!!!!
                THANX TO EVERYBODY THAT HELPED ME, ESPECIALY TO aib!!!!
                • aib
                  • Jan 2014
                  • 1615
                  #23
                  My congratulations!
                  Sincerely yours,
                  Aleksey
