Notifications not sending emails
  • jfha73
    • Aug 2018
    • 33
    I have a user configured to use Media=>Email using GMail, SMTP, Using SSL/TLS port 465 and configured that same user to get an email for every Warning and Critical events that Zabbix records, so far there has been no critical, but I did see a warning the other day and no email showed up for that user, what else do I need to check to make this happen?
    This is how the user's Email Media is setup:
Name:	Screen Shot 2018-09-17 at 3.02.12 PM.png
    Thanks.
  • DmitryL
    • May 2016
    • 278
    Check reports -> Action log (maybe there were some errors)
    If there are no entries, check permissions of User group on affected Host group. It must have at least read permissions.
    • jfha73
      • Aug 2018
      • 33
      It says: Failed sending data to the peer: MAIL failed: 530
      I don't know why, it works on all other applications I have sending emails.
      • jfha73
        • Aug 2018
        • 33
        Never mind,
        I re-configured the Media Email and it's now working the way it's supposed to.
        Thanks anyway.
