Zabbix with Ruckus r600
  • eduber
    • Sep 2018
    Greetings dear community
    this is one of my first posts and I hope you can help me, I would like to know if you have or know of any template by SNMP to monitor the RUCKUS R600 devices, which I have currently linked 2 Ruckus R600.
    Thank you for your answers.
  • DeltaCentral
    • Jul 2018
    • 19
    Please see details which I have setup on my system and working.
    Zabbix Front End
    ### Create A (Host) With Following Details ###
    Hostname: RK600 (Name Of Your Choice)
    SNMP Interface: IP Address Of Your Device / Port 161
    Template (Tab)
    Select: Template Module Interfaces Simple SNMPv2
    Macros (Tab)
    Macro: {$SNMP_COMMUNITY}
    Value: " This Will Be Your Public Key, See Below, Call It What You Want"
    Change Auto-dDiscovery Update Value For Template (Template Module Interfaces Simple SNMPv2)
    From 3600 (60 Minutes) To 600 (10 Minutes)
    Ruckus Access Point SNMP Setup
    1. Setup Public Key In GUI Front End Ruckus Access Point
    OR
    2. Use Putty and Connect To Access Point and Make Changes Via This Method.
    SNMP CLI Usage Options:
    Usage: set snmp
    -> community ro <name> -- read-only community name
    -> community rw <name> -- read-write community name
    -> manager <ip> -- SNMP manager IP address
    rkscli: set snmp community ro public
    OK
    rkscli: set snmp community rw private
    OK
    rkscli: set snmp manager Zabbix Server IP
    OK
    rkscli: get snmp
    SNMP ro community : public (Public Key)
    SNMP rw community : private
    SNMP manager : Zabbix Server IP
    OK
    Hope this information helps you and others, let me know if it works for you.
    Jags
