Proc.Num returns 0 in zabbix 3.4.11
  • ben maina
    • Jun 2017
    • 17
    Trying to monitor apache using the following:
    proc.num[apache2,www-data]
    But it always returns 0 yet when i do top command i can see there are several processes for apache.
    This is happening in zabbix 3.4.11
    Any assistance how i can monitor my linux services? Thanks in advance
  • kloczek
    • Jun 2006
    • 1771
    try run on the host:
    strace -fe trace=file /usr/sbin/zabbix-agentd -t 'proc.num[apache2,www-data]'
    • ben maina
      • Jun 2017
      • 17
      kloczek when i run that command on the host machine i get this.
      strace: Can't stat '/usr/sbin/zabbix-agentd': No such file or directory
      • kloczek
        • Jun 2006
        • 1771
        Typo .. /usr/sbin/zabbix_agentd
        • ben maina
          • Jun 2017
          • 17
          kloczek when i ran it again i get the following output:
          execve("/usr/sbin/zabbix_agentd", ["/usr/sbin/zabbix_agentd", "-t", "proc.num[ap ache2,www-data]"], [/* 20 vars */]) = 0
          access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
          access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
          open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libssl.so.1.0.0", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libcrypto.so.1.0.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libldap_r-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/liblber-2.4.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libcurl.so.4", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libresolv.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libpcreposix.so.3", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libsasl2.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libgssapi.so.3", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libgnutls.so.30", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libpthread.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libidn.so.11", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/librtmp.so.1", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libpcre.so.3", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libheimntlm.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libkrb5.so.26", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libasn1.so.8", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libcom_err.so.2", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libhcrypto.so.4", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libroken.so.18", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libp11-kit.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libtasn1.so.6", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libnettle.so.6", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libhogweed.so.4", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libgmp.so.10", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libkrb5.so.3", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libk5crypto.so.3", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libkrb5support.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libwind.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libheimbase.so.1", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libhx509.so.5", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libsqlite3.so.0", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = 3
          open("/usr/lib/x86_64-linux-gnu/libffi.so.6", O_RDONLY|O_CLOEXEC) = 3
          open("/lib/x86_64-linux-gnu/libkeyutils.so.1", O_RDONLY|O_CLOEXEC) = 3
          open("/dev/urandom", O_RDONLY) = 3
          open("/etc/zabbix/zabbix_agentd.conf", O_RDONLY) = 4
          stat("/etc/zabbix/zabbix_agentd.d", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
          open("/etc/zabbix/zabbix_agentd.d", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 5
          stat("/etc/zabbix/zabbix_agentd.d/postgresql.conf", {st_mode=S_IFREG|0644, st_si ze=11849, ...}) = 0
          open("/etc/zabbix/zabbix_agentd.d/postgresql.conf", O_RDONLY) = 6
          stat("/etc/zabbix/zabbix_agentd.d/..", {st_mode=S_IFDIR|0755, st_size=4096, ...} ) = 0
          stat("/etc/zabbix/zabbix_agentd.d/.", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
          stat("/etc/zabbix/zabbix_agentd.d/userparameter_mysql.conf", {st_mode=S_IFREG|06 44, st_size=1531, ...}) = 0
          open("/etc/zabbix/zabbix_agentd.d/userparameter_mysql.conf", O_RDONLY) = 6
          open("/etc/nsswitch.conf", O_RDONLY|O_CLOEXEC) = 4
          open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 4
          open("/lib/x86_64-linux-gnu/libnss_compat.so.2", O_RDONLY|O_CLOEXEC) = 4
          open("/lib/x86_64-linux-gnu/libnsl.so.1", O_RDONLY|O_CLOEXEC) = 4
          open("/lib/x86_64-linux-gnu/libnss_nis.so.2", O_RDONLY|O_CLOEXEC) = 4
          open("/lib/x86_64-linux-gnu/libnss_files.so.2", O_RDONLY|O_CLOEXEC) = 4
          open("/etc/passwd", O_RDONLY|O_CLOEXEC) = 4
          open("/proc", O_RDONLY|O_NONBLOCK|O_DIRECTORY|O_CLOEXEC) = 4
          open("/proc/1/cmdline", O_RDONLY) = 5
          open("/proc/1/status", O_RDONLY) = 6
          open("/proc/2/cmdline", O_RDONLY) = 5
          open("/proc/2/status", O_RDONLY) = 6
          open("/proc/3/cmdline", O_RDONLY) = 5
          open("/proc/3/status", O_RDONLY) = 6
          open("/proc/5/cmdline", O_RDONLY) = 5
          open("/proc/5/status", O_RDONLY) = 6
          open("/proc/7/cmdline", O_RDONLY) = 5
          open("/proc/7/status", O_RDONLY) = 6
          open("/proc/8/cmdline", O_RDONLY) = 5
          open("/proc/8/status", O_RDONLY) = 6
          open("/proc/9/cmdline", O_RDONLY) = 5
          open("/proc/9/status", O_RDONLY) = 6
          open("/proc/10/cmdline", O_RDONLY) = 5
          open("/proc/10/status", O_RDONLY) = 6
          open("/proc/11/cmdline", O_RDONLY) = 5
          open("/proc/11/status", O_RDONLY) = 6
          open("/proc/12/cmdline", O_RDONLY) = 5
          open("/proc/12/status", O_RDONLY) = 6
          open("/proc/13/cmdline", O_RDONLY) = 5
          open("/proc/13/status", O_RDONLY) = 6
          open("/proc/15/cmdline", O_RDONLY) = 5
          open("/proc/15/status", O_RDONLY) = 6
          open("/proc/16/cmdline", O_RDONLY) = 5
          open("/proc/16/status", O_RDONLY) = 6
          open("/proc/17/cmdline", O_RDONLY) = 5
          open("/proc/17/status", O_RDONLY) = 6
          open("/proc/18/cmdline", O_RDONLY) = 5
          open("/proc/18/status", O_RDONLY) = 6
          open("/proc/20/cmdline", O_RDONLY) = 5
          open("/proc/20/status", O_RDONLY) = 6
          open("/proc/21/cmdline", O_RDONLY) = 5
          open("/proc/21/status", O_RDONLY) = 6
          open("/proc/22/cmdline", O_RDONLY) = 5
          open("/proc/22/status", O_RDONLY) = 6
          open("/proc/23/cmdline", O_RDONLY) = 5
          open("/proc/23/status", O_RDONLY) = 6
          open("/proc/25/cmdline", O_RDONLY) = 5
          open("/proc/25/status", O_RDONLY) = 6
          open("/proc/26/cmdline", O_RDONLY) = 5
          open("/proc/26/status", O_RDONLY) = 6
          open("/proc/27/cmdline", O_RDONLY) = 5
          open("/proc/27/status", O_RDONLY) = 6
          open("/proc/28/cmdline", O_RDONLY) = 5
          open("/proc/28/status", O_RDONLY) = 6
          open("/proc/30/cmdline", O_RDONLY) = 5
          open("/proc/30/status", O_RDONLY) = 6
          open("/proc/31/cmdline", O_RDONLY) = 5
          open("/proc/31/status", O_RDONLY) = 6
          open("/proc/32/cmdline", O_RDONLY) = 5
          open("/proc/32/status", O_RDONLY) = 6
          open("/proc/33/cmdline", O_RDONLY) = 5
          open("/proc/33/status", O_RDONLY) = 6
          open("/proc/35/cmdline", O_RDONLY) = 5
          open("/proc/35/status", O_RDONLY) = 6
          open("/proc/36/cmdline", O_RDONLY) = 5
          open("/proc/36/status", O_RDONLY) = 6
          open("/proc/37/cmdline", O_RDONLY) = 5
          open("/proc/37/status", O_RDONLY) = 6
          open("/proc/38/cmdline", O_RDONLY) = 5
          open("/proc/38/status", O_RDONLY) = 6
          open("/proc/40/cmdline", O_RDONLY) = 5
          open("/proc/40/status", O_RDONLY) = 6
          open("/proc/41/cmdline", O_RDONLY) = 5
          open("/proc/41/status", O_RDONLY) = 6
          open("/proc/42/cmdline", O_RDONLY) = 5
          open("/proc/42/status", O_RDONLY) = 6
          open("/proc/43/cmdline", O_RDONLY) = 5
          open("/proc/43/status", O_RDONLY) = 6
          open("/proc/45/cmdline", O_RDONLY) = 5
          open("/proc/45/status", O_RDONLY) = 6
          open("/proc/46/cmdline", O_RDONLY) = 5
          open("/proc/46/status", O_RDONLY) = 6
          open("/proc/47/cmdline", O_RDONLY) = 5
          open("/proc/47/status", O_RDONLY) = 6
          open("/proc/48/cmdline", O_RDONLY) = 5
          open("/proc/48/status", O_RDONLY) = 6
          open("/proc/49/cmdline", O_RDONLY) = 5
          open("/proc/49/status", O_RDONLY) = 6
          open("/proc/50/cmdline", O_RDONLY) = 5
          open("/proc/50/status", O_RDONLY) = 6
          open("/proc/51/cmdline", O_RDONLY) = 5
          open("/proc/51/status", O_RDONLY) = 6
          open("/proc/52/cmdline", O_RDONLY) = 5
          open("/proc/52/status", O_RDONLY) = 6
          open("/proc/53/cmdline", O_RDONLY) = 5
          open("/proc/53/status", O_RDONLY) = 6
          open("/proc/54/cmdline", O_RDONLY) = 5
          open("/proc/54/status", O_RDONLY) = 6
          open("/proc/55/cmdline", O_RDONLY) = 5
          open("/proc/55/status", O_RDONLY) = 6
          open("/proc/56/cmdline", O_RDONLY) = 5
          open("/proc/56/status", O_RDONLY) = 6
          open("/proc/57/cmdline", O_RDONLY) = 5
          open("/proc/57/status", O_RDONLY) = 6
          open("/proc/58/cmdline", O_RDONLY) = 5
          open("/proc/58/status", O_RDONLY) = 6
          open("/proc/59/cmdline", O_RDONLY) = 5
          open("/proc/59/status", O_RDONLY) = 6
          open("/proc/63/cmdline", O_RDONLY) = 5
          open("/proc/63/status", O_RDONLY) = 6
          open("/proc/64/cmdline", O_RDONLY) = 5
          open("/proc/64/status", O_RDONLY) = 6
          open("/proc/65/cmdline", O_RDONLY) = 5
          open("/proc/65/status", O_RDONLY) = 6
          open("/proc/66/cmdline", O_RDONLY) = 5
          open("/proc/66/status", O_RDONLY) = 6
          open("/proc/82/cmdline", O_RDONLY) = 5
          open("/proc/82/status", O_RDONLY) = 6
          open("/proc/83/cmdline", O_RDONLY) = 5
          open("/proc/83/status", O_RDONLY) = 6
          open("/proc/84/cmdline", O_RDONLY) = 5
          open("/proc/84/status", O_RDONLY) = 6
          open("/proc/85/cmdline", O_RDONLY) = 5
          open("/proc/85/status", O_RDONLY) = 6
          open("/proc/86/cmdline", O_RDONLY) = 5
          open("/proc/86/status", O_RDONLY) = 6
          open("/proc/87/cmdline", O_RDONLY) = 5
          open("/proc/87/status", O_RDONLY) = 6
          open("/proc/88/cmdline", O_RDONLY) = 5
          open("/proc/88/status", O_RDONLY) = 6
          open("/proc/89/cmdline", O_RDONLY) = 5
          open("/proc/89/status", O_RDONLY) = 6
          open("/proc/90/cmdline", O_RDONLY) = 5
          open("/proc/90/status", O_RDONLY) = 6
          open("/proc/91/cmdline", O_RDONLY) = 5
          open("/proc/91/status", O_RDONLY) = 6
          proc.num[apache2,www-data] [u|10]
          +++ exited with 0 +++
          • kloczek
            • Jun 2006
            • 1771
            So it works
            • ben maina
              • Jun 2017
              • 17
              Yes. Was wondering why on zabbix its always 0
              • zux
                • Sep 2018
                • 97
                proc.num[apache2,www-data] - means - how many processes with name apache2 from user www-data running?
                Is apache really running from user www-data?
                You can try using just proc.num[apache2] to see if there are any processes at all.
                Also, run
                ps -aux | grep apache
                to see what user is apache running as.
                • ben maina
                  • Jun 2017
                  • 17
                  zux yes apache2 is running as www-data user.Also if i do proc.num[apache2] still output is 0 yet i can clearly see processes running for apache2
                  • zux
                    • Sep 2018
                    • 97
                    Can you add the output of:
                    ps aux | grep apache
                    • ben maina
                      • Jun 2017
                      • 17
                      zux here is the output:
                      root 6359 0.0 0.1 377240 33352 ? Ss Sep20 2:03 /usr/sbin/apache2 -k start
                      www-data 8293 0.0 0.0 380760 17160 ? S 06:25 0:00 /usr/sbin/apache2 -k start
                      www-data 8294 0.0 0.0 381100 22556 ? S 06:25 0:00 /usr/sbin/apache2 -k start
                      www-data 8295 0.0 0.0 380760 18024 ? S 06:25 0:00 /usr/sbin/apache2 -k start
                      www-data 8296 0.0 0.0 381100 22776 ? S 06:25 0:00 /usr/sbin/apache2 -k start
                      www-data 8297 0.0 0.0 380800 19088 ? S 06:25 0:00 /usr/sbin/apache2 -k start
                      www-data 10190 0.0 0.0 380760 20564 ? S 06:35 0:00 /usr/sbin/apache2 -k start
                      www-data 13252 0.0 0.0 381100 21960 ? S 09:54 0:00 /usr/sbin/apache2 -k start
                      root 13877 0.0 0.0 14224 940 pts/0 S+ 09:57 0:00 grep --color=auto apache
                      • ingus.vilnis
                        • Mar 2014
                        • 908
                        proc.num[,,,apache2]
                        • ben maina
                          • Jun 2017
                          • 17
                          ingus.vilnis With that still the output is 0. on zabbix UI the type am using to monitor is zabbix agent (active) i hope that is okay too.Find screenshot attached to ocunter check if i have done everything correctly.
                          • zux
                            • Sep 2018
                            • 97
                            I'm starting to think, that the host you are trying to monitor and the one you are getting data from are different. If the hostname is not configured exactly the same way in agent and server, this can happen.
                            To be completely sure that you are monitoring the correct host, I would recommend renaming this host to something absolutely unique in both, the server and agent (agent needs to be restarted after that.
                            • ingus.vilnis
                              • Mar 2014
                              • 908
                              #15
                              With the active check you should wait at least few minutes before checking for the values to arrive.
                              Item configuration is fine with one exception that setting the update interval to 1 second is not the best practice. 1 minute would be much more appropriate.
                              If you have access to the command line the you can try executing
                              zabbix_agentd -t proc.num[,,,apache2]
