How do I create a service/daemon check?
  • jfha73
    • Aug 2018
    • 33
    I have Zabbix monitoring a Linux Server, this server has a service/daemon that I want to monitor (make sure it's running), how can I do that?
    Thanks,
  • zux
    • Sep 2018
    • 97
    Look for item "proc.num[]"
    • jfha73
      • Aug 2018
      • 33
      If I do that, what if the Proc.num changes because the server was restarted, or the service itself was restarted, the process number will change eventually, I need something more stable than that.
      Thanks though.
      • zux
        • Sep 2018
        • 97
        Can you define that service like this? If at least one process is running, then the service is running. The just define the trigger to fire when proc.num < 1
        • jfha73
          • Aug 2018
          • 33
          I might have misunderstand, I was thinking that Proc.num was the same as PID, but for what you're saying, it looks like is a processes count, anyway, how can I set that up? what do I need to put in the Expression of the Trigger for the service I'm trying to monitor?
          Thanks.
          • jfha73
            • Aug 2018
            • 33
            I should have made my question clearer, so here it is better worded.
            What do I need to create and how so I can have a check for a service/daemon on a Linux server?
            For example: create an Application, then an Item, then a trigger, etc. explaining how to do each one of them.
            Thanks,
            • jfha73
              • Aug 2018
              • 33
              Thanks for this, I finally have it up and running using this.
