Trigger with value same on a period
  • Filter
    I need your help for to create a trigger.
    I would like a check if my new value is the same as the previous on a period of 30 minutes.
    I saw that there is this one : Diffrence between last and previous value is = N but it doesn't consider the time.
    Can you help me ?
    "delta" trigger function seem to do it.
    https://www.zabbix.com/documentation...gers/functions
    item_key.delta(30m)}=0
      I'll test, i don't know this function. Thank you.
      Announcement
      No announcement yet.
