Custom alertscript for messenger, curl multiline processing error
  • Just_a_newb
    • Nov 2018
    Hello!
    I'm trying to implement Rocket.Chat notifications (aside from standard e-mail ones) via custom alertscript in bash. I use the same action to send notifications for e-mail and the messenger.
    Here's my action:
    Default subject: {HOST.NAME} - [{TRIGGER.STATUS}], {TRIGGER.NAME}
    Default message:
    Problem started at {EVENT.TIME} on {EVENT.DATE}
    Host: {HOST.NAME}
    Severity: {EVENT.SEVERITY}
    Trigger description:
    {TRIGGER.DESCRIPTION}
    Original problem ID: {EVENT.ID}
    And here is the script:
    #!/bin/bash
    SUBJECT="$2"
    MESSAGE="$3"
    # Sending message
    curl -s -H "Content-Type: application/json" -d "{\"username\":\"zabbix\",\"text\":\"$( echo "$SUBJECT\n$MESSAGE" | sed 's/"/\\\"/g' )\"}" https://rchat.trololo.com/hooks/zSUM_HooK_HERE
    E-mail notifications work just fine but messenger ones never arrive. I changed DebugLevel=5 in server config to catch the problem and that's what i found:
    26811:20181127:152739.307 /usr/lib/zabbix/alertscripts/rocketsend.sh '#zabb' 'alt8test.trololo.com - [PROBLEM], "AUTH module" check failed' 'Problem started at 15:27:37 on 2018.11.27
    Host: alt8test.trololo.com
    Severity: High
    "AUTH module" check failed at the step 1:
    response code "502" did not match any of the required status codes "200"
    Step 1 - Login
    Step 2 - AUTH test
    Step 3 - Logout
    Original problem ID: 126342' output:
    <!DOCTYPE html>
    <html lang="en">
    <head>
    <meta charset="utf-8">
    <title>Error</title>
    </head>
    <body>
    <pre>Bad Request</pre>
    </body>
    </html>
    26811:20181127:152739.307 In zbx_ipc_socket_write()
    26811:20181127:152739.307 End of zbx_ipc_socket_write():SUCCEED
    Apparentely curl can't process the output from ALERT.MESSAGE because it's multiline. When i made additional messenger-specific action with default message consisted of only one line it worked fine. My Linux knowledge is very limited, i tried to fix it several ways including by using herein and variables but didn't succeed probably due to my general dumbassness. I could live with oneliners in messenger but this just bugs me so much so i thought i'd try to ask on forum and here i am
