Hello All,
Is it possible to only send a actions when the monitor has been completely down for more then 5 minutes.
Example: Temperature raises above 72 F. AC turns but takes 3 minutes to get temperature below 72 F. At 5 minutes the temp is below 72 F and a action is not needed.
I've tired combining 2 triggers into one, like "{(EXAMPLETEMPLATE):Temp.last(0)}>72 & {(EXAMPLETEMPLATE):Temp..min(5m)} = 0)" with no success.
Also tired
{Device:Temp.last(300)}>71
Also tired
