Zabbix4: Receiving notifications with 'PROBLEM' only
  • s0r1n
    • Feb 2013
    • 23
    After upgrade to version 4 we are receiving emails with 'PROBLEM' only, the ones with 'OK' are missing. In version 3 everything worked fine.
    Do you have any clue, is there any setting to fix it, pls?
  • troffasky
    • Jul 2008
    • 639
    Configuration > Actions > [your action] > Recovery operations tab.
    • s0r1n
      • Feb 2013
      • 23
      Great, it worked!
      As regards to the table of Configuration > Actions, I guess you should add in the future releases new columns for 'Recovery operations' respectively 'Update operations'...
      Thanks!
