creating custom dashboard views
  • tatapoum
    • Jan 2014
    • 185
    #16
    There may be a conflict somewhere.
    1) in /dashboards, only keep default.erb
    2) in /jobs, only keep zabbix.rb
    3) in /widgets, only keep zabbix, zabbix_list and text folders
    Then restart dashing.
    • hatchetharris
      • Aug 2014
      Dashing help
      Now I have 10 vertical dots on a blank page.......
      • tatapoum
        • Jan 2014
        • 185
        #18
        Do you have a recent browser ?
        Does dashing work if you create a new project somewhere :
        dashing new myproject
        cd myproject
        bundle
        dashing start
        • Jason
          • Nov 2007
          • 431
          #19
          I have the vertical dots too...
          Its not my dashing install as I use it other places too...
          I'm wondering if it's the screen cycling part of it?
          No errors in thin.log file...
          • tatapoum
            • Jan 2014
            • 185
            #20
            You can debug the widgets by adding :
            Dashing.on 'ready', ->
            Dashing.debugMode = true
            To their *.coffee file and restarting dashing. The output will be displayed in the javascript console of your browser.
            You need to have a recent browser to make this work.
            • Jason
              • Nov 2007
              • 431
              #21
              I've enabled the debugging...
              This is looking promising...
              Error: ExecJS::RuntimeError: [stdin]:84:15: error: unexpected =
              documentWidth = $(document).width()
              (in /usr/local/dashing/bhl_twitter/assets/javascripts/cycleDashboard.coffee) application.js:1
              ReferenceError: $ is not defined <- This points to the line $(function() {
              Dashing.cycleDashboards({timeInSeconds: 30, stagger: true});
              It looks like it's the integration of the screen cycling that is the issue...
              • tatapoum
                • Jan 2014
                • 185
                #22
                Could you post your default.erb and zabbix.rb files somewhere (pastebin, etc) ? Don't forget to remove the passwords.
                • Jason
                  • Nov 2007
                  • 431
                  #23
                  Pasted here http://pastebin.com/agi0n6yg with both files on 1 screen... few blank lines between each...
                  • Jason
                    • Nov 2007
                    • 431
                    #24
                    Ah-ha!...
                    Got it... I'd copied the cycleDashboards.coffee file, but without the indenting... Replaced it with the correct version with the indenting and it's at least showing me something now...
                    • tatapoum
                      • Jan 2014
                      • 185
                      #25
                      Hum, don't know if you misconfigured something with the cycling feature...
                      Try to create a fixed dashboard for "Screen 1", replace default.erb by the one here : http://pastebin.com/Hz9WXRWX.
                      Does it work ?
                      • Jason
                        • Nov 2007
                        • 431
                        #26
                        It was the indenting on cycleDashboards.coffee that was the problem... I needed to click through to get the raw data and them paste that over...
                        Is there a easy method of getting all host groups in a screen without having to specify all the host groups on a line?
                        For our use we probably don't want it cycling screens...
                        Jason
                        • Jason
                          • Nov 2007
                          • 431
                          #27
                          Sorted it by using the fixed first screen and commenting out the groupid filter...
                          • dvwyngaa
                            • Mar 2014
                            • 49
                            #28
                            Tatpoum,
                            I'm having the same issue with the "dots". See attached screenshot. I don't think indenting is an issue, as I have copy and pasted the cycleDashboard.coffee file and all seems well.
                            Any ideas what this would or where I should be looking?
                            Regards,
                            Dawid
                            • Jason
                              • Nov 2007
                              • 431
                              #29
                              On the github screen both where you installed the cycling screen and the zabbix application itself you need to click on the raw link and copy the contents of that screen to keep the indenting intact... Otherwise it doesn't preserve it correctly and causes issues...
                              Also in the dashing folder there is a log folder with a thin.log file in it... Paste the last dozen or so lines from that...
                              Jason
                              • dvwyngaa
                                • Mar 2014
                                • 49
                                #30
                                Jason,
                                Thanks for the response. I have clicked to the "raw" contents on the link and pasted that through. Indenting looks fine.
                                With regards to the thin.log, I can't find such a file or directory in the dashing folder.
                                Regards,
                                Dawid
