Dear All,
Our infrastructure uses Zabbix 2.2. My current dilemma is the following one:
I would like to discover and monitor filesystems using low-level discovery but also distribute different discovery rules over several templates which could be linked to a given host.
The rationale behind this is to have a common base template for our hosts that monitors standard local filesystems (i.e. ext3/4, zfs, xfs). Some exceptional hosts would then be linked to a supplementary specific template to also monitor another type of filesystem (i.e. cvfs and fhgfs) using a different regex for the FSTYPE.
The idea of having 2 templates is to keep host configuration more easy to manage, that is, without overriding items/discovery rules of a template at the host level.
The problem we encounter is that the discovery key "vfs.fs.discovery" has to be unique, so when we want to link this supplementary template to a host we get a "key already in use" error. The same is true for the item prototype keys.
I understand the reasons for this, but I would like to know if somebody has an elegant solution for this kind of problem?
Any ideas are welcome
Kind regards,
Volker
Kind regards,
Volker
