Zabbix proxy is unable to discover devices
  • bharat_yitrobc
    • Jan 2019
    i have setup a local ubuntu server which im using to discover devices which works fine .
    Similarly i've setup a zabbix proxy in ubuntu 18.04 vm which is unable to discover devices using the discovery rule mentioned in below image
    Used this link http://yallalabs.com/linux/how-to-in...ntu-16-04-lts/ for guidance other than zabbix documentary.
    The zabbix proxy is running and last seen works fine
    Can someone provide me with suggestions to debug this issue
    Thanks in advance
  • LenR
    • Sep 2009
    • 1011
    Do you have StartDiscoverers > 0 in the zabbix_proxy.conf?
    • bharat_yitrobc
      • Jan 2019
      Default setting StartDiscoverers =1 is set
