Backing up Zabbix 4.0
  • mjventer
    • Feb 2019
    Hello, I am a Linux Novice, and I got my Zabbix running for a week now and have added over 100 devices.
    Can anyone point me in the direction of a more in-depth guide for a backup method?
    Kind Regards,
    Jaco
  • LenR
    • Sep 2009
    • 1011
    If you are mysql, some people use this https://zabbix.org/wiki/Docs/howto/mysql_backup_script. It doesn't include the history and trend data, but it's a lot faster than a simple mysqldump. I found the restore time for mysqldump to be unworkable if it included the history and trend data.
    I use https://www.percona.com/software/mys...ona-xtrabackup for a full backup weekly, but it has the ability to take daily backups based off the weekly.
    • boyemillar
      • Nov 2015
      • 33
      Wesley Schaft has created a newer script which catches all the new tables added into Zabbix 4.0 it still skips the History and Trend tables.
      https://github.com/wschaft/zabbix-backup
