vfs.dir.size does not work
  • MichaelF
    • Feb 2019
    • 66
    Hello!
    I have the vfs.dir.size item set to [c:\folder1] but it keeps saying "No such file or directory" regardless of syntax being used (e.g. "c:\folder1", 'c:\folder1' etc.)... ???
    OS = Windows Server 2019
    Thank you in advance,
    Michael
  • andris
    Zabbix developer
    • Feb 2012
    • 228
    What if vfs.dir.size[C:\\folder1] ? Or vfs.dir.size[C:/folder1] ?
    • MichaelF
      • Feb 2019
      • 66
      The same
      • andris
        Zabbix developer
        • Feb 2012
        • 228
        Does vfs.dir.size[] work with any other folder?
        • MichaelF
          • Feb 2019
          • 66
          Seems it doesn't work with any folder - either "No such file or directory" or "Timeout..." (all other items - including vfs.fs.size[c:,pfree] - work fine).
          • andris
            Zabbix developer
            • Feb 2012
            • 228
            "Timeout..." seems a good sign here - that directory is being counted but has a lot of files. You can try to set DebugLevel=4 in zabbix_agentd.conf and restart the agent. Later, when problem is solved , you can restore it back to DebugLevel=3.
            Note that in zabbix_agentd.conf by default there is Timeout=3. You can set up to Timeout=30 (seconds).
            • MichaelF
              • Feb 2019
              • 66
              I've set Timeout=30 and Debug=30 and restarted the agent - the result: I can see now in the log all my items ("Requested [vfs.fs.size[c:,pfree]] and etc.") but the vfs.dir.size string does not exist in the log! ???
              • MichaelF
                • Feb 2019
                • 66
                After ~5-10 minutes the vfs.dir.size item has worked out! Andris, thank you very much for your help!
                Regards,
                Michael
