Data is not being collected
  • max.ch.88
    • Oct 2018
    • 206
    #16
    Disable discovery. What are you trying to find?
    • MichaelF
      • Feb 2019
      • 66
      #17
      Yes, of course. Seems I was wrong: on the first server all items had worked only once as on the second server - Zabbix was just displaying that first values on the hosts page for ~ a week...
      • MichaelF
        • Feb 2019
        • 66
        #18
        "Disable discovery. What are you trying to find?" - sorry, didn't get it... I'm trying to understand why the items added to my hosts stopped producing any values - just 1 item for each host still works.
        • max.ch.88
          • Oct 2018
          • 206
          #19
          Originally posted by MichaelF
          P.S. ZABBIX keeps complaining "Problem: Zabbix discoverer processes more than 75% busy" - is it normal for a virtual machine (Hyper-V) with two virtual processors and 4GB of RAM providing there're only two hosts to monitor and 7 items for each host?
          What are you using discoverer processes for?
          • brunohl
            • Mar 2019
            • 215
            #20
            Please post your item configuration for the SIZE itens. And also please check your queue on "Administration >> Queue", just in case.
            • MichaelF
              • Feb 2019
              • 66
              #21
              1) vfs.dir.size[c:\exchange]
              2) vfs.fs.size[c:,pfree]
              "Administration >> Queue = all zeros.
              • brunohl
                • Mar 2019
                • 215
                #22
                If you can, upload a screenshot of itens configuration
                • MichaelF
                  • Feb 2019
                  • 66
                  #23
                  Here they are:
                  • brunohl
                    • Mar 2019
                    • 215
                    #24
                    Well, that's strange...
                    Everything seems correct..
                    What you receive when you run?
                    zabbix_get -s 10.1.1.11 -k vfs.dir.size[c:\exchange]
                    And
                    zabbix_get -s exch1.testenterprise.net -k vfs.dir.size[c:\exchange]
                    Also, run "ps aux | grep zabbix" on your server and post results to see if your workers are ok.
                    • MichaelF
                      • Feb 2019
                      • 66
                      #25
                      "What are you using discoverer processes for?" - just for thesting purposes... Disabled it.
                      zabbix_get -s 10.1.1.11 (or exch1...) -k vfs.dir.size[c:\exchange] = ZBX_Notsupported ... No such file or directory. - This strange because this item was returning earlier either "Timeout" or (after increasing timeout to 30sec) - the real directory size value. Now DirSize returns the error (No such file or directory) for ANY existing folder. ps aux | grep zabbix - please see the attachments (17-0 - the first screen with the -more option, 17 - the second one without -more).
                      • max.ch.88
                        • Oct 2018
                        • 206
                        #26
                        Is this problem with ms-windows servers only? What is the timeout value in zabbix_agentd.conf?
                        • MichaelF
                          • Feb 2019
                          • 66
                          #27
                          Is this problem with ms-windows servers only? - yes, I haven't deploy Zabbix agent to any other computer yet. Timeout = 30sec.
                          • brunohl
                            • Mar 2019
                            • 215
                            #28
                            Try running:
                            zabbix_get -s exch1.testenterprise.net -k vfs.dir.size[c:/exchange]
                            • MichaelF
                              • Feb 2019
                              • 66
                              #29
                              zabbix_get -s exch1.testenterprise.net -k vfs.dir.size[c:/exchange] = Timeout. Anyway, the previous [c:\exchange] did work at first!
                              • brunohl
                                • Mar 2019
                                • 215
                                #30
                                OK, but I guess you have to use as "vfs.dir.size[c:/exchange]". On my Windows Server it only works that way.
                                So, Timeout, is Timeout, either you will have to find a way to execute it faster, or find another way of doing this.
                                Maybe zabbix_sender + zabbix_trapper? active agent?
                                I don't know what best suit your needs.
