newbie help - how to create a history count
  • sbaker
    • Jun 2014
    I'm new to zabbix, and been trying to find this thru the documentation, but I've not found my answer yet and I need to try and put this together today.
    How do I get a daily graph of the numbers of a certain type of triggers across a set of systems. IE how many "x" alerts have I seen across "y" group systems laid out in count per day for a period of days.
    I have found the report bar graph, and using
    "distribution of values across items"
    I Select the timeframe, but in Items add,
    I can't find a way to essentially do a count per day of
    all "disk space less than x" alerts across all hosts in a parameter set window.
    But it only seems to let me select just one host at a time.
    I've looked at a count of the other report types and can't find anything yet.
    Am I using the right structure/feature? Is there some place in the docs that I just haven't found?
    Thanks in advance.
  • fleon
    • Aug 2014
    • 22
    I have basically the same question.
    We have a trigger set up when ping fails to a host. And we have 60 hosts monitored (cisco switches and routers).
    I would like to have a report of some sorts that tells me how many times ping failed at night for all devices.
    Every graph or report i try to make it only lets me monitor individual items not triggers themselves.
    Even trigger type screens only shows you current trigger's status , you can't put a timeframe on them.
    • aib
      • Jan 2014
      • 1615
      A couple of words about triggers: you can easily get a list of triggers for 7 days (for example) , by using Monitoring -> Triggers tab. (see attached picture)
      Let me know if it's not the same which are you asked about.
      Sincerely yours,
      Aleksey
      • fleon
        • Aug 2014
        • 22
        It seems that option has a bug, because no matter how many days i use, it only is showing me the triggers of today.
        Yesterday i had ping failures, got the emails and everything, but i am not seeing them there.
        EDIT: when a trigger is resolved, the value changes to OK. Whoops. I had only "problem". Thanks, this is good enough, although i would have preferred this to be done as a graphic.
        • bbrendon
          • Sep 2005
          • 873
          You can create custom reports. Its just a reporting interface and SQL query away.
          Check the forums, people have done it.
          Unofficial Zabbix Expert
          Blog, Corporate Site
