VMware CPU Usage in percentage
  • Luis Pereira
    • Apr 2019
    Hello, there!
    I'm using VMware template to monitoring a VMware host.
    The CPU usage item returns data in Hz.
    Is there a way to monitoring CPU usage by percentage, instead Hz?
    Thank you in advanced!
  • only_one_me
    • May 2019
    You can divide it by CPU freq (vmware.hv.hw.cpu.freq) multiplied by threads (vmware.hv.hw.cpu.threads).
    • only_one_me
      • May 2019
      Nah, just use vmware.hv.perfcounter[{$URL},{HOST.HOST},"cpu/usage[average]"] or vmware.hv.perfcounter[{$URL},{HOST.HOST},"cpu/utilization[average]"]
      • Luis Pereira
        • Apr 2019
        Hello!
        Thank you.
        I have had this idea.
        It's working fine!
        • Andrey123987456
          • Apr 2019
          • 44
          Good day everyone. Please tell me how to set one parameter in zabbix. There is a network node, you need to select the parameter when the node was last on the network and time was written. Who can tell which way is best done.
          • ybuddhika
            Banned
            • Jul 2019
            Can anyone provide a way to monitor VMware memory usage in percentage?
            • yasith
              • Aug 2019
              Hello everyone,
              To get VMware CPU usage as a percentage I created a new key on my template (Template VM VMware Hypervisor).
              But after 1 min interval, I got an error with that "performance counter is not available"
              In the below, I attached the images related to how I create a new item and what is the error I got.
              Please give me feedback to solve this.
              Thank you in advance!
              • acatic1
                • Oct 2019
                • 38
                Originally posted by Luis Pereira
                Hello!
                Thank you.
                It's working fine!
                Could you share a screenshot of how you configured that? Thank you!
                • Jipso11
                  • Jan 2020
                  last("vmware.hv.memory.used[{$URL},{$UUID}]")/last("vmware.hv.hw.memory[{$URL},{$UUID}]")*100
                  • zaheerabbas1988
                    • Feb 2020
                    • 22
                    Need help, getting the value greater than 100. I tried to change formula order but nothing seems to be working.
                    • vingertop
                      • Apr 2020
                      I put in a preprocessing step on that item :
                      Afterwards the graphs and triggers work as expected :
Name:	cpu graph.PNG
                      • zaheerabbas1988
                        • Feb 2020
                        • 22
                        @vingertop thank you, it solved my problem
                        • ahmetselman
                          • Sep 2020
                          Can somebody add screenshot of item (CPU Usage in percentage) because even i add the key vmware.hv.perfcounter[{$URL},{HOST.HOST},"cpu/usage[average]"] there is no data...
                          • Jason Cage
                            Jason Cage commented
                            You could have a try key = vmware.hv.perfcounter[{$URL},{HOST.HOST},"cpu/utilization[average]"]
                            It works in my environment.
                        • ZaBeast
                          • Sep 2019
                          • 42
                          Create new item set “Name” to “CPU usage (%)”, “Key” to vmware.hv.perfcounter[{$URL},{HOST.HOST},”cpu/usage[average]”] , “Type of information” to “Numeric (float), and “Unit” to “%”.
                          Note that there is another option if you cannot get the data about CPU percentage using the key vmware.hv.perfcounter[{$URL},{HOST.HOST},”cpu/usage[average]”]. Create a new item, set type to "Calculated", "Key" can be anything, "Type of information" to "Numeric (float)", and "Unit" to "%". Then in "formula" section divide CPU Hz (vmware.hv.cpu.usage) by the CPU frequency (vmware.hv.hw.cpu.freq) and multiplied by the threads (vmware.hv.hw.cpu.threads)
                          You can c/p that formula and find more information in this tutorial:
                          https://bestmonitoringtools.com/vmwa...ring_in_Zabbix
                          • ismailsarp
                            • Feb 2023
                            You can run it as follows.
                            VMware: Memory usage (%)
                            vmware.hv.perfcounter[{$VMWARE.URL},{$VMWARE.HV.UUID},"mem/usage[average]"]
                            VMware: CPU usage (%)
                            vmware.hv.perfcounter[{$VMWARE.URL},{$VMWARE.HV.UUID},"cpu/utilization[average]"]
                            I tried zabbix 6.2.6 version. Working fine.
