VMware CPU Usage in percentage
  • diegodaloiso
    • Jan 2021
    Hi ismailsarp , do you how to monitor those items over an specifict time lapse? I need a trigger for "vmware.hv.cpu.usage.perf[{$VMWARE.URL},{$VMWARE.HV.UUID}]" , if cpu utilization is over 90% more than 10 minutes. Thanks!
    • ismailsarp
      • Feb 2023
      You can do as below​.
      You can change time (5m or 10m)
      1) Add a new macros for Vmware Hypervisors template;
      Macro:
      {$CPU.UTIL.CRIT}
      Value: 90 (you can change it as you want)
      2) And add a new trigger for High CPU
      Event Name: ​
      High CPU utilization (over {$CPU.UTIL.CRIT}% for 5m)
      Operational Data:
      Current utilization: {ITEM.LASTVALUE1}
      Expression:
      min(/VMware Hypervisor/vmware.hv.perfcounter[{$VMWARE.URL},{$VMWARE.HV.UUID},"cpu/utilization[average]"],5m)>{$CPU.UTIL.CRIT}
      3) And Create trigger actions for alarm High CPU
      And now you can get alarms.
      I send alarm email and MicrosoftTeams platform same time
      Good luck !
      • derli1988
        • Apr 2021
        • 60
        #18
        Good day zabbix community
        I'm trying to get RAM Usage in percentage for Hypervisors.
        Using that item key:
        vmware.hv.perfcounter[{$VMWARE.URL},{$VMWARE.HV.UUID},"mem/usage[average]"]
        However, I'm getting the percentage wrong
        VMware: Memory usage in percents
        36m 2s 4232 %
        The value is sort of correct, except it is multiplied by 100.
        • ismailsarp
          • Feb 2023
          36m 2s 4232 %
          Did you add custom multiplier as follows ?
          • derli1988
            • Apr 2021
            • 60
            #20
            LIFE SAVIOUR
            • derli1988
              • Apr 2021
              • 60
              #21
              It works like a charm
