Help with tweaking a template
  • gunemalli
    • May 2019
    Hi All,
    I need some help in tweaking a template to suite our needs. I'm new to zabbix and these kind of work is over my head still.
    The template in question: https://share.zabbix.com/network_dev...ikrotik-snmpv2 (Advanced Template Net Mikrotik SNMPv2)
    The issue I'm having is with the interface discovery. I only want to discover two interfaces: ether1 and pppoe type interfaces.
    If anyone can help me with this or at least point me in the right direction, that would be great.
    Kind Regards,
  • Mike2K
    • Oct 2018
    • 60
    You could use the regex function...
    Go to Administration -> General -> Regular expressions (that is a dropdown)
    Create a new regex, name it anything you want and create an expression like:
    Result is TRUE - ether1
    Result is TRUE - pppoe
    Next, go into your template -> discovery rules -> "your discovery rule" -> Filters -> create a new filter like:
    {#SNMPVALUE} matches @your regex name
    Please let us know if that works...
    You can look at the Windows, Linux and Cisco templates, they all have these rules in place.
    • drgr33n
      • Dec 2015
      • 13
      Maybe add a preprocessing step? I'm not sure as I'm not a Zabbix guru but couldn't you add a validation preprocessing step to filter out the discovered devices? If not, craft a static rule from the LLD declaration.
      • drgr33n
        • Dec 2015
        • 13
        Ignore me, Mike2K's answer sounds like the cleanest way to achieve the desired outcome.
