Show cpu load of router internal processes through Zabbix?
  • redes
    • Jun 2014
    Hello all.
    It is possible to view a graph of cpu load of an internal router process?
    For example in a Cisco router you can view the internal processes and the cpu they are using with the command show processes cpu.
    Is there a way I can create an item that uses SNMP and get specific data from a specific internal process of a router?
    Thanks in advance.
  • jan.garaj
    • Jan 2010
    • 506
    If you are able to collect data, then it's possible.
    I think that you can collect only total CPU metrics with SNMP. CPU utilization per process is not available trough SNMP way:
    http://www.cisco.com/c/en/us/support...util-snmp.html
    But you can probably use telnet:
    http://www.cisco.com/c/en/us/support...hcpu.html#snmp
    and then just parse output from "show processes cpu" and send it to Zabbix with zabbix_sender.
    Anyway read manual of your Cisco device, what is (not) possible :-)
    • redes
      • Jun 2014
      Hi.
      The only thing i did is collect total cpu via SNMP as you said.
      So you say use Telnet to connect to the router, type in the show processes command, export it as txt and finally send it with zabbix_sender right?
      And I must configure and new item using Zabbix trapper?
      • jan.garaj
        • Jan 2010
        • 506
        Yes, exactly.
        Eventually you can use telnet checks - https://www.zabbix.com/documentation.../telnet_checks
        , but efficiency will be worse, because you have to make telnet for every metric.
