Ping check on external host
  • yash_25
    • May 2019
    • 41
    I want to ping an external host where there is no zabbix agent installed on it.
    I have created a user parameter on zabbix server
    UserParameter=Ping_check[*],/sbin/fping $1 -t 100 | grep alive | wc -l
    I have created an item on Zabbix UI. Please check the below attached file
    After creating the item it is showing this error as not supported(dont know why)
Name:	item error.PNG
    I have created a trigger with the below expressions
    {Zabbix server:Ping_check.nodata(5m)}=1
    {Zabbix server:Ping_check.last()}=0
    I am not sure why the item is showing as unsupported and what expression should be used in the trigger. could you please help me with this
  • brunohl
    • Mar 2019
    • 215
    Check and upload the message when you click on the red square.
    Also, your key definition is wrong. When you set your item you specify a parameter "$1", but when you create your item you're not passing it. So it should be something like Ping_check[IP_THAT_YOU_WANT_TO_PING]
    • yash_25
      • May 2019
      • 41
      Hi Brunohl,
      Thanks for the response and here we are passing the parameter for multiple hosts not just a single host, can you help me with it and when I created the item it is showing not supported(you can see it in the attached files) do you know why?
      • brunohl
        • Mar 2019
        • 215
        There's no attachment that shows the message of why is not supported. If you have multiple hosts, you should create an item for each one of them.
        • yash_25
          • May 2019
          • 41
          It shows unsupported item key. Is the Item creation is wrong?
          Let me know if you have any idea about it
Name:	ping error.png
          • brunohl
            • Mar 2019
            • 215
            Ah, ok. You have to restart your agent to your new key apply.
            • yash_25
              • May 2019
              • 41
              Is there any way to add the keys without restart?
              • brunohl
                • Mar 2019
                • 215
                No, it's not possible
                • yash_25
                  • May 2019
                  • 41
                  Thanks Brunohl. Will do it first and let you know if I face any other issues
                  • yash_25
                    • May 2019
                    • 41
                    I tried restarting the zabbix host and still it is showing the same as not supported key
                    • yash_25
                      • May 2019
                      • 41
                      Sorry it is working now.
                      • yash_25
                        • May 2019
                        • 41
                        Hi bruno,
                        I would like to test whether the ping is working or not
                        I created this trigger
                        Let me know if this works or not.
                        • brunohl
                          • Mar 2019
                          • 215
                          I guess this it would work
                          • yash_25
                            • May 2019
                            • 41
                            Thanks for your help bruno
                            • yash_25
                              • May 2019
                              • 41
                              #15
                              Hi Bruno,
                              Can you help me with this https://www.zabbix.com/forum/zabbix-...meric-unsigned
