What is the difference between 'day' and 'day so far'?
  • cesarsj
    • Dec 2018
    • 154
    I was seeing in Problems, that when applying certain periods, the results are the same for Day and Day so fa. Doubt is also valid for week and year.
  • ingus.vilnis
    • Mar 2014
    • 908
    You will not see a difference in Problems view.
    Open any graph and click on the same time selectors, you will see that one displays full day till next midnight 23:59 (with no data for period in the future), while the other displays values from last midnight 00:00 till current time.
    • cesarsj
      • Dec 2018
      • 154
      Thanks for the answer. Then it's as if these options are unnecessary in Problems View.
      • ingus.vilnis
        • Mar 2014
        • 908
        The time filter apparently was designed to fit all possible locations. Having two separate filters for graphs and problems would raise even more questions.
        • cesarsj
          • Dec 2018
          • 154
          I understood. Thanks for the answers.
