How can I force a check?
  • WilliamSG
    • Jun 2014
    • 41
    Hi ppl!
    Well, I'm trying some configurations on my zabbix, but everytime I make a change, I need to wait few minutes to Zabbix check the host... I think it occours automaticaly every 5 minutes (is it ?)
    Well, is there anyway to force a single check on the host, or can I change this scheule?
    I did a look into confs but nothing found .. =(
  • jvalenzani
    • Sep 2010
    • 53
    Force config cache reload using the -R option.
    $ zabbix_server -R config_cache_reload
    DOC-> https://www.zabbix.com/documentation.../zabbix_server
