Host dependencies & triggers
  • RayCic
    • Jul 2014
    How to implement host dependencies by using triggers?
    I understand this in simple cases: when self made trigger on one
    host depends on self made trigger on other.
    But I want to make all triggers (from templates, self made etc)
    on one host depend on single trigger from other
    Is this right way to do:
    1) Configuration->Hosts
    2) Click on "Triggers" for required host
    3) Select all triggers
    4) Choose "Mass update" and press "Go"
    5) Click "Replace dependencies"
    6) Add required trigger
    7) Click "Save"
    If this is right way to do, then how to deal on third step with
    triggers which have grayed check box?
  • BDiE8VNy
    • Apr 2010
    • 680
    See: ZBXNEXT-46
