Hi Everyone,
I'd appreciate some help if possible as I'm slowly loosing the will to live
I posted recently about getting Zabbix up and running, due to a fault of my own the Virtual Machine was lost and I've had to start again, however this time rather than using Zabbix 1.8 I have opted to use version 2.2
i keep getting this error message.
I've found LOADS of threads on this forum about this problem and links to other sites but so far nothing i have changed or tried has made any difference.
I am running Zabbix 2.2.5, the server, GUI & database are all running from the same machine and i have switched on the Local agent to monitor the server and this is where the error is coming from.
The Server is a Centos 6.5 64Bit Minimal installation that has nothing else installed.
I dont know if this is a config file issue or a server problem at the moment but its the only constant warning i am getting.
the Tail of zabbix_server.log & Agent are below.
zabbix_server.log
zabbix_agent.log
zabbix_server.log
zabbix]# tail /var/log/zabbix/zabbix_server.log 22877:20140806:143419.701 server #26 started [self-monitoring #1] 22843:20140806:143419.897 server #6 started [poller #4] 22844:20140806:143419.901 server #7 started [poller #5] 22842:20140806:143419.910 server #5 started [poller #3] 22841:20140806:143419.913 server #4 started [poller #2] 22845:20140806:143419.917 server #8 started [unreachable poller #1] 22839:20140806:143419.919 server #3 started [poller #1] 22864:20140806:143419.945 server #19 started [discoverer #1] 22859:20140806:153419.624 executing housekeeper 22859:20140806:153419.629 housekeeper [deleted 0 hist/trends, 0 items, 0 events, 0 sessions, 0 alarms, 0 audit items in 0.003542 sec, idle 1 hour(s)] [root@odo zabbix]#
zabbix]# tail /var/log/zabbix/zabbix_agentd.log 22596:20140806:141724.027 Starting Zabbix Agent [Zabbix server]. Zabbix 2.2.5 (revision 47411). 22596:20140806:141724.032 using configuration file: /etc/zabbix/zabbix_agentd.conf 22597:20140806:141724.042 agent #0 started [collector] 22598:20140806:141724.048 agent #1 started[listener #1] 22599:20140806:141724.050 agent #2 started[listener #2] 22600:20140806:141724.051 agent #3 started[listener #3] 22601:20140806:141724.052 agent #4 started [active checks #1] [root@odo zabbix]#
