How to monitor my ISP uptime and internet speed (download and upload)
  • gcherem
    • Aug 2019
    Hi there, My ISP is pretty unreliable, and I would like to monitor the uptime and internet speed. So I am thinking about to install Zabbix in a Raspberry PI and view some charts on the browser or thru my iPhone. Which template can I use to achive that?
  • ishaqbbk
    • Aug 2019
    • 9
    Dear,
    On which device your internet is terminating, Monitor that device WAN Interface, Thats it...........simple.
    • gcherem
      • Aug 2019
      Hi ishaqbbk, thank you for your reply. I am newbie with zabbix. Is there a sample or recipe that I can follow?
      • ishaqbbk
        • Aug 2019
        • 9
        Dear,
        Configure the mail alert, once the internet link will go down you will get a mail and once that is recovered then also you will get a mail.
        • gcherem
          • Aug 2019
          Hi there, thank you again. But how about the internet speed? Download and uploat rate? What do you suggest?
