Problem monitoring vmware server
  • dimir
    Zabbix developer
    • Apr 2011
    • 1080
    #16
    You only need to create a single host for esxi host and link template VMware to it. Everything else should be created automatically. Do not create the hypervisor hosts manually.
    • vmiro
      • Sep 2022
      Originally posted by danthemann
      Old thread but this is not working for me.
      I am still getting the unknown hypervisor UUID after confirming I have the correct Hypervisor UUID, username, password, URL.
      Click image for larger version  Name:	image.png Views:	1259 Size:	7.1 KB ID:	450708
      Click image for larger version  Name:	image.png Views:	1249 Size:	33.3 KB ID:	450709
      SDK soap is running (on by default)
      https://SERVERIP/sdk/vimService.wsdl
      Click image for larger version  Name:	image.png Views:	1233 Size:	5.8 KB ID:	450710​
      {$VMWARE.HV.UUID} is correct.
      UUID is same both from esxcfg-info -u |awk '{print tolower($0)}'
      ​and web (https://SERVERIP/mob/?moid=ha-host&d...are.systemInfo)
      Click image for larger version  Name:	image.png Views:	1231 Size:	27.7 KB ID:	450711
      I have waited 24 hours.
      I have tried removing the template and re-adding.
      Tried with the VMware template, tried setting the variable as {$VMWARE.UUID} or {$VMWARE.VM.UUID}
      Tried this on 3 hypervisors.
      One esx 5.5 and 2 on 6.5.
      Tried with both read-only accounts and ESX root account.
      /etc/zabbix/zabbix_server.conf:
      ​StartVMwareCollectors=5
      ​VMwareCacheSize=64M
      any thoughts or suggestions?
      Hi, I have exactly the same problem. Tried with different ESXi hosts and versions. I'm using only one "VMWare" template for ESXi host. Zabbix discover only datastore and nothing elase.
      I'm using a proxy with zabbix server. ESXi hosts are accessed via proxy. I set config files (on both server and proxy) for the VMWare related options as suggested.
      I tried increasing a log verbosity on proxy, and I see it reads some data from hosts related to VMs. I have more hosts monitored with this proxy and have no problem retrieving data.
      But, nothing is shown on Zabbix server except four items for datastore.
      I have MACROs defined. Tried with UUID macro and without...
      Zabbix version is 6.0.9.
      What am I doing wrong ?
      Thanks​
