Problem monitoring vmware server
  • john_s
    • Aug 2014
    I'm trying to monitor a server running esxi 5.0.0 (stand-alone, free hypervisor)
    I installed zabbix and it seems to be running ok. (version 2.2.5)
    I manually added a host configuration for my vmware machine.
    I linked 'Template Virt Vmware' to my host.
    Discovery reported an error - I forget - something about HOST.HOST
    I saw this thread
    It mentioned changing {HOST.HOST} to {$UUID}
    I exported 'Template Virt Vmware Hypervisor', changed {HOST.HOST} to {$UUID}, changed the name to 'Template Virt Vmware Hypervisor2', and imported it.
    I unlinked 'Template Virt Vmware' and linked 'Template Virt Vmware2' to my host.
    I created a macro for my host's UUID.
    It successfully connected to the vmware host and populated a list of the virtual machines (in configuration / host).
    But now there are messages in /var/log/zabbix like this:
    vmware host:vmware.hv.datastore.discovery[{$URL},{HOST.HOST}] changed: unknown hypervisor uuid
    I'm new to zabbix, so can someone explain what is going on?
    Should it work with vmware stand-alone, free hypervisor?
    Do I have something configured wrong?
    Or is that a limitation of the existing system?
    If I want to monitor several vmware servers, do I have to manually set them up with their UUID?
    Any words of wisdom would be greatly appreciated.
  • aib
    • Jan 2014
    • 1615
    Well, I did it like it was described in documentation.
    1) Create vSphere host
    2) Add 3 macros:
    - {$USERNAME} - username which has an administrative privileges on VMware
    - {$PASSWORD) - password for username
    - {$URL} - https://10.10.10.10/sdk (where 10.10.10.10 is the address of vSphere host, not VMware supervisor)
    3) Add 3 templates to vSphere host:
    - Template Virt VMware
    - Template Virt VMware Guest
    - Template Virt VMware Hypervisor
    4) Waited for a couple of hours (lunch/over night/take a vacation) and I got all my hypervisors/guest machines discovered)
    Where is your problem on that short way?
    Sincerely yours,
    Aleksey
    • john_s
      • Aug 2014
      still odd
      I deleted the discovered hosts and started over
      I did what you said except in step 3 I just linked the template virt vmware
      (the docs say not to link the other 2)
      After a while it got a list of my vm guests.
      So now I have 2 questions:
      1. The log file has some messages like : vmware.vm.memory.size.private[{$URL},{HOST>HOST}] became not supported: value is not available.
      Is that normal?
      (some of my vm's are off - could that be the cause?)
      2. under configuration / hosts, I have entries for my vm's like this:
      Discover VMware VMs: guest 1
      Discover VMware VMs: guest 2
      On the right hand side, the 'availability' column has 4 greyed out icons.
      Is that right?
      Thanks!
      • aib
        • Jan 2014
        • 1615
        - Did your discovery process found all Hypervizors?
        - It's correct to have greyed icon "availability", because you don't have any Zabbix Agent installed on Discovered Guests.
        - Yes, some of Items are unavailable in my configuration also. I don't know why.
        Sincerely yours,
        Aleksey
        • Pro21
          • Jun 2008
          • 13
          Maybe I come after the war but I've fighed a couple of hours before understand how to setup an ESXI monitoring.
          Below a simple process to handle a working monitoring.
          Replace in the template Template Virt VMware Hypervisor all variable {HOST.HOST} by {$UUID}.
          Add macro as explain ($USERNAME, $PASSWORD, $URL) and the last macro $UUID.
          $UUID can be obtain by requesting the hypervisor webservices like https://hostnamme/mob/?moid=ha-host&...are.systemInfo You will see data like uuid "320d4e35-b3fd-11e3-a216-6cae8b33fc28" where string between "" is the data to used in $UUID macro.
          After the trick the monitoring is working ... Last thing change also {HOST.HOST} to {$UUID} in the autodiscover menu of the template.
          Good Luck
          • renanmvc
            • Feb 2014
            • 12
            aonde encontro o uuid?
            Good Luck
            aonde encontro esse UUID?
            Esse link acima está indisponível
            • spritluo520
              • Sep 2016
              unknown virtual machine uuid
              hi all:
              My ZABBIX is 2.4.8, I am ready to monitor the esxi host, but there are several monitoring items show "virtual machine UUID unknown", I would ask what is the problem
              • hernan
                • Sep 2016
                • 67
                Hello guys,
                I have the same error with Zabbix 3.2.4 and VCenter 5.5.
                Can you help me with this?
                Thanks in advance.
                Regards.
                • DanielB
                  • Jun 2017
                  This error only happen in an stand alone ESX host (at least that i have tested). As @Pro21 said, you have to put the UUID as a macro variable, if you get an error trying to enter to the URL https://<hostname>/mob/?moid=ha-host&doPath=hardware.systemInfo, you have check if your ESX has enabled The Managed Object Browser feature (VMWARE KB: https://kb.vmware.com/selfservice/mi...rnalId=2108405). Apart of that, everything is working fine.
                  Thanks @Pro21 for your help.
                  • DanielB
                    • Jun 2017
                    Good Luck
                    • maciejhpl
                      • Dec 2017
                      you don't have to do that
                      when you add new host in zabbix
                      Host name: 320d4e35-b3fd-11e3-a216-6cae8b33fc28
                      Visible name: esxi-name
                      {HOST.HOST} = "Host name"
                      • magicker
                        • Apr 2019
                        if it helps you can get the uuid from the cli of an esxi server with :
                        esxcli system uuid get
                        My problem is that none of these rules seem to get actual information about the metrics of the ESXI host eg cpu / ram etc just info on the guest.. am I missing something?
                        • r3wt3d
                          • Feb 2021
                          I know it's old thread but there were no correct answer to this problem, so I leave the solution here.
                          You need to write the InstanceUUID to the HOST and not the UUID you can get it from the vCenter vm list.
                          To receive the correct InstanceUUID use this script below I found on the web or get it from /mob.
                          Script:
                          vCenterからESXiと仮想マシンの情報を取得してExcelファイルで出力するツール. Contribute to sky-joker/vmware-InvEx development by creating an account on GitHub.
                          From /mob:
                          • danthemann
                            • Mar 2022
                            • 10
                            Old thread but this is not working for me.
                            I am still getting the unknown hypervisor UUID after confirming I have the correct Hypervisor UUID, username, password, URL.
                            SDK soap is running (on by default)
                            https://SERVERIP/sdk/vimService.wsdl
                            {$VMWARE.HV.UUID} is correct.
                            UUID is same both from esxcfg-info -u |awk '{print tolower($0)}'
                            ​and web (https://SERVERIP/mob/?moid=ha-host&d...are.systemInfo)
                            I have waited 24 hours.
                            I have tried removing the template and re-adding.
                            Tried with the VMware template, tried setting the variable as {$VMWARE.UUID} or {$VMWARE.VM.UUID}
                            Tried this on 3 hypervisors.
                            One esx 5.5 and 2 on 6.5.
                            Tried with both read-only accounts and ESX root account.
                            /etc/zabbix/zabbix_server.conf:
                            ​StartVMwareCollectors=5
                            ​VMwareCacheSize=64M
                            any thoughts or suggestions?
                            • danthemann
                              • Mar 2022
                              • 10
                              #15
                              Running on Zabbix 6.2.
                              Note, these are standalone ESXi hosts (merely trying to monitor datastores for events).
                              I believe the InstanceUUID solution (one post above mine) will correct if a VM instance UUID has same UUID as a hypervisor.
                              When I navigate the MOB I see no duplicate and would be extremely hesitant to run the reconfigureVM method to change VM instance UUIDs.
                              in 5.5 vsphere client its easy to see the virtual guest (InstanceUUID) to see there is no conflict with the HV UUID.
                              Click image for larger version  Name:	image.png Views:	0 Size:	31.2 KB ID:	450714​​​
                              Anyone else having any problems with VMware hypervisor templates on standalone ESX hosts ?
