Monitoring over Serial
  • GR06LBS
    • Oct 2019
    i have a project with zabbix and need to monitor a "apc smart ups 1500" but we dont have a Network Managment Card. The only thing i have is a serial interface. That is connected to my Zabbix server. Is it possible to monitor this usv?
    Patrick
  • 1berto
    • Sep 2018
    • 182
    Do you have a command that read the value you want from the port? If so you can use an UserParameter of a system.run key
    Maybe you will need to install the zabbix Agent on the Zabbix Server Machine and add the Server as a host ...
    Check the documentation about UserParameter and system.key
    • Hamardaban
      • May 2019
      • 2713
      In case ups connected to the computer with Windows and on this computer is installed PowerShute - you receive the ability
      to contact data of ups by snmp (requests are sent to the address of the computer)
