i have read http://www.zabbix.com/manual_cookbook.php -
"Novell
Use MRTG Extension Program for NetWare Server (MRTGEXT.NLM) agent for Novell. The agent is compatible with protocol used by ZABBIX. It is available from http://forge.novell.com/modules/xfmod/project/?mrtgext.
Items have to be configured of type Zabbix Agent and must have keys according to the MRTGEXT documentation.
For example:
* UTIL1
1 minute average CPU utilization
* CONNMAX
Max licensed connections used
* VFKSys
bytes free on volume Sys:
Full list of parameter supported by the agent can be found in readme.txt, which is part of the software. "
So I have created a template called NetWare_t. I have attempted to create an item but can't find a key to suit mrtgext (i am pressing the select button next to the "key" entry). I have also tried just typing UTIL1 and MRTGEXT.UTIL1 in as the key but these don't work either.
Basically i can't work out what to type for the key, to tell zabbix to communicate to mrtgext.nlm. I see in another thread that others have worked it out (but never wrote what they worked out), but i lack the skill here :-(
Adding an example to what is written in the cookbook would also be good thanks.
i am using v1.1.1 of zabbix.
thanks in advance
H
"Novell
For example:
* UTIL1
* CONNMAX
* VFKSys
thanks in advance
H
