Zabbix 4.0 bulk acknowledge
  • siili
    • Sep 2013
    • 16
    Maybe this should be posted to bugs but on the chance I don't know what I'm doing, I shall try here first.
    I recently upgraded proxies and server from Zabbix version 3.4 to version 4.0. There doesn't appear to be a mechanism to acknowledge more than one event at a time, except when selecting multiple events, then using Mass update. When clicking on the item in the Problems tab under the Ack heading, the expected window opens allowing acknowledgement with a message. However, the Scope settings do not appear to matter one way or the other. And what does "Selected and all other problems of related triggers" even mean? Presumably, it should include the selected trigger and all others for the same type for the same machine at least. But there is no discernible difference as far as I can tell. Note that selecting multiple items before clicking on "No" under Ack makes no difference. When using Mass update there appears to be no change in outcome.
    Regards,
    David Koski
  • siili
    • Sep 2013
    • 16
    Note that with previous versions (pre 4), bulk acknowledge worked by selecting one event, even though version 3.4 had a bug that did not acknowledge events older than some threshold.
    • manosnms
      • Jun 2020
      • 52
      Is there any solution on this subject?
      thanks
