How to convert a string to number (unsigned) by preprocessing?
  • cesarsj
    • Dec 2018
    • 154
    For example, I want to convert 'abc: 12345' to number '12345'
    I tried with:
    1 step: \nabc: (.*)
    2 step: Regular expression, parameter '\D+' and Output '/1'
    But the exit resulted in nothing.
  • Atsushi
    • Aug 2013
    • 2028
    Name: Regular expression
    Parameter1: abc: ([0-9].+)
    Parameter2: \1
    • cesarsj
      • Dec 2018
      • 154
      It hasn't worked yet, the error below appears. 'abc' was a way of simplifying, the correct one would be the line below Timestamp, where I left your suggestion, with a little more detail: '\nTimestamp of last test: ([0-9].+)'. Thus the error below arose.
      Item preprocessing step #1 failed: cannot perform regular expression match: pattern does not match, type "string", value "Model Family: unknown
      Device Model: ST4000VX000-1F4168
      Serial Number: Z307EQ0C
      SMART overall-health self-assessment test result: PASSED
      User Capacity: 4,000,787,030,016
      No Error Logged: 1
      Short tests errors: 0
      Timestamp of last test: 1576232101"
      • cesarsj
        • Dec 2018
        • 154
        I did it! This worked: \ nTimestamp of last test: \ t (. *)
        • Hamardaban
          • May 2019
          • 2714
          Try don't use \n at begin of regex. Or use ".*Timestamp of last test: ([0-9].+)"
          • cesarsj
            cesarsj commented
            "Try don't use \n at begin of regex",
            Because?
        • Hamardaban
          • May 2019
          • 2714
          Because of the ambiguity of what line feed is used (\n matches a line-feed (newline) character (ASCII 10)) and whether it is there at all.
          At all it is difficult say something on regular expressions not possessing original(!) lines'.
          Works? that's nice...
