Unknown CA errors between Zabbix Proxy and remote Zabbix Server
  • ZapDragon
    • Feb 2020
    Forgive me ahead of time.
    Its 04:00 and I've been at this all day. I will likely make mistakes in this post, if I haven't already.
    I have a Zabbix server hosted on a VPS and I want to setup Zabbix proxies in a few locations to help keep the monitoring centralized.
    The Server has been up for over a year by itself without issue. I now want to expand that to my network setup at a remote location.
    I have a Proxy VM setup in VMware 6.7 and everything seems to be fine except that I can't get my pre-purchased certificate to work.
    I am using a wildcard domain SSL Certificate from GlobalSign sold by AlphaSSL. The certificate is already setup as a HTTPS certificate and works fine.
    Am I unable to use these kidns of certificates?
    Below is the error I am getting.
     25324:20200203:122021.277 failed to accept an incoming connection: from x.x.x.x: unable to get local issuer certificate: TLS handshake set result code to 1: file ../ssl/statem/statem_srvr.c line 2931: error:1417C086:SSL routines:tls_process_client_certificate:certificate verify failed: TLS write fatal alert "unknown CA"
     25324:20200203:122022.726 failed to accept an incoming connection: from x.x.x.x: unable to get local issuer certificate: TLS handshake set result code to 1: file ../ssl/statem/statem_srvr.c line 2931: error:1417C086:SSL routines:tls_process_client_certificate:certificate verify failed: TLS write fatal alert "unknown CA"
     25324:20200203:122024.171 failed to accept an incoming connection: from x.x.x.x: unable to get local issuer certificate: TLS handshake set result code to 1: file ../ssl/statem/statem_srvr.c line 2931: error:1417C086:SSL routines:tls_process_client_certificate:certificate verify failed: TLS write fatal alert "unknown CA"
    This is the exact error I get from Zabbix's log.
    I have downloaded and re-downloaded the CA cert countless times to no avail.
    Any suggestions or questions?
  • ZapDragon
    • Feb 2020
    With even more tinkering, I have not managed to get anywhere.
    Does anyone have any suggestions?
    • Hamardaban
      • May 2019
      • 2714
      It is not necessary that the error indicates a problem with certificates - problems can be in different ways... For example, in the openssl version or supported ciphers (for more information, see the documentation and support). Try starting on the PSK first.
      • tim.mooney
        • Dec 2012
        • 1432
        Ok, well, what did you do with the CA after you downloaded it?
        What OS and version is your Zabbix server, and your Zabbix proxy? Assuming a relatively modern Linux system, does that system use the ca-certificates package? A lot of the most popular Linux vendors have switched to using that for managing their CA trust.
        If your OS does use the ca-certificates package to manage the list of trusted CAs, did you follow the steps from your vendor for installing a new CA, including the 'update-ca-certificates' or 'update-ca-trust' (depending on your vendor) to rebuild the trusted bundle?
        Finally, are you certain you're downloading the correct CA? If it's a GlobalSign cert generated by AlphaSSL, there are probably intermediate CA certificates involved. Are you getting the correct one?
        • ZapDragon
          • Feb 2020
          Thank you for your response Tim.
          I put it into a file called cert.ca in my Certs directory and put the path to it in the configuration file for both the Server and Proxy.
          Both Servers are running Debian 10. If there was a change to how CAs were handled, I was unaware.
          My vendor doesnt seem to provide steps beyond "copy paste" into a text editor for installing the certificates. I also have never really had to install CA certificates before now. I assumed it was the same process for Crt and Key certs.
          This is where I got my CA Certificates for my vendor Under R1
          I also stumbled across this one and had the same results.
          I am 80% certain I am. I have double and triple checked to be sure, as I can be.
          • tim.mooney
            • Dec 2012
            • 1432
            A few years ago, there wasn't a well-defined procedure for managing CAs on different Linux distros. There were sometimes large differences in how you added the CA, and it also depended on whether the software was built to use (linked against) openssl, GnuTLS, NSS, etc.
            These days, it seems like most distributions are converging on the 'ca-certificates' package, and a tool, often called update-ca-certificates, that rebuilds the combined file from separate CA files that have been installed in a couple of places on the system. For example, for Debian, see this documentation .
            If you run the following two commands and report the output back here, it might help narrow down where the problem is.
            First on the wildcard certificate, run the following command to report the exact issuer for your wildcard:
            openssl x509 -in [I]your_wildcard_cert_file_here[/I] -noout -issuer
            Next, on the CA certificate you downloaded, run the following command to report both its subject and its issuer:
            openssl x509 -in [I]your_CA_certificate_file_here[/I] -noout -issuer -subject
            Remember that both the certificate and CA are public, so there's no security risk for sharing this particular information. It's the private key that needs to be carefully protected.
            If you send along the results from those two commands, it may help point which direction to investigate further.
