I'm using highcharts to draw graph. With shorter date range I can use the history.get and no issues. But longer date it takes ages for history.get to return data. so I used trend.get
When do you use trend.get ? how would you put trend data in highcharts since trend.get return max, man and avg? Do you use avg ? I would like to match the highcharts graph with grafana.
Any help or guides would be highly appreciated..
Thank you
Dave
Thank you
Dave
