Discovery Item, LLD, Jsonpath bug?
  • HaveDill
    • Sep 2014
    • 103
    According to Zabbix's documentation, since 4.2 we have not needed the "data" field for json values.
    Note that since Zabbix 4.2, the format of the JSON returned by low-level discovery rules has been changed. It is no longer expected that the JSON will contain the "data" object. Low-level discovery will now accept a normal JSON containing an array, in order to support new features such as the item value preprocessing and custom paths to low-level discovery macro values in a JSON document.
    Built-in discovery keys have been updated to return an array of LLD rows at the root of JSON document. Zabbix will automatically extract a macro and value if an array field uses the {#MACRO} syntax as a key. Any new native discovery checks will use the new syntax without the "data" elements. When processing a low-level discovery value first the root is located (array at $. or $.data).
    However, on 4.4.3 i constantly need to write custom javascript to put a json return into a data array. Am i hitting a weird bug, or am i reading the documentation wrong? My json return from Jenkin's api is valid, and so are my json paths.
Name:	2020-02-25 09_30_57-Window.png
  • 20k
    • Apr 2017
    • 18
    I'm facing the same behaviour already reported here: https://www.zabbix.com/forum/zabbix-...the-data-array
    As you said, I need to write my custom External scripts to bypass this, which is a bit annoying.
    I'm still hope we can get an answer to clarify this.
    20k
    • 20k
      • Apr 2017
      • 18
      Thank for your reply.
      I've been handling JSON for years and I'm sure it is valid.
      The case I reported last October was just an example but I had other similar issues with other valid JSON.
      It just seem to me that the JSON Path based discovery unfrtunately still expect the data array and I did not found any documentation regarding this.
