How do you logout?
  • fbicknel
    • Mar 2020
    How do you logout?
    The gui doesn't seem to have a logout means. How do you logout?
    $ zabbix_server --version
    zabbix_server (Zabbix) 4.0.18
    Revision 688cd21456 21 February 2020, compilation time: Feb 21 2020 15:17:24
    Copyright (C) 2020 Zabbix SIA
    License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it according to
    the license. There is NO WARRANTY, to the extent permitted by law.
    This product includes software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org/).
    Compiled with OpenSSL 1.0.1e-fips 11 Feb 2013
    Running with OpenSSL 1.0.1e-fips 11 Feb 2013
  • tim.mooney
    • Dec 2012
    • 1436
    Can you screenshot the upper right corner of your Zabbix web interface and post it here?
    There should be a symbol/icon that looks like the power button (semi-circle on the bottom, single verticle line on the top) in the top right corner. If you mouse over that, it should pop up a tool tip saying "Sign out".
    If you'ure missing that icon, you may want to force a browser refresh, to see if it's something with your browser.
    • fbicknel
      • Mar 2020
      Here ya go....
Name:	Screenshot from 2020-03-04 15-29-40.png
      And here's Firefox (admin, hence the different theme)
Name:	Screenshot from 2020-03-04 15-31-16.png
      I don't see any power buttons that you described.
      I can start a private browser session and it forgets who I am, but no amount of cookie clearing seems to fix it.
      • yujizmq
        • Feb 2019
        ZABBIX.logout()
        Try input this in F12 "Console" Tab.
        4.0.16 frontend has no issue:
        • fbicknel
          • Mar 2020
          Thanks. That worked.
          and
          now that I know where it is, when I hover the mouse there the Sign out hint pops up. Not sure why none of those things are appearing, though. I don't know enough about it, but I would bet CSS is to blame.
          • fbicknel
            • Mar 2020
            Hm. Now that I know that user widget is there next to the logout, I tried changing themes. That works: it will change the theme, but these upper right icons still don't appear. I somehow think that has something to do with CSS, too. But it's not supporting my previous hypothesis. I found where in the CSS it was mentioned. Not sure how to proceed from there, though. I thought the obvious thing to do would be to search my home directory for a file by that name (icon-sprite.svg) appearing on line 277, but none appears in any directory named img.
            Apparently that should be served, though: it appears in /usr/share/zabbix/assets/img.
            I'll poke at that with a stick for a while.
            • fbicknel
              • Mar 2020
              Hm. Well, that looks pretty normal. I give up.
