Firewall - Opening ports
  • zabbix_woc
    • Feb 2020
    • 9
    Running 4.4.4 of the Zabbix appliance, I need to open the following ports
    TCP 8014, 8016 and 8021
    UDP 67 and 69
    The documentation states
    4 Firewall
    By default, only the ports listed in changes are open. To open additional ports just modify “/etc/iptables/rules.v4” or “/etc/iptables/rules.v6” files and reload firewall rules:
    service iptables-persistent reload"
    It makes it sound so simple, but on opening /rules.v4 I have added INPUT entries (in what i believe is the correct format), but the reload of the firewall rule command results in:
    "unrecognized service"
    Please can someone point me in the correct direction here?
  • zabbix_woc
    • Feb 2020
    • 9
    For anyone else looking at this I have disabled the firewall entirely by entering the following:
    sudo ip6tables -F
    sudo iptables -F
    It may be wrong but I was stuck on what to do next!
    • tim.mooney
      • Dec 2012
      • 1436
      Rather than leaving your appliance with no firewall, can you see if this answer helps: https://askubuntu.com/questions/9413...istent-service
      I suspect it's just a case of outdated documentation in the Zabbix docs.
