URL monitoring - web check issues
  • tiberiu.buzea
    • Apr 2020
    Hi guys,
    I'm heaving some troubles trying to create a web monitoring for a URL like:
    http://<name>/example/index.html
    On this page I've created variables for user and password to insert them into login fields. After hitting the submit button the link will change to (theoretically) :
    http://<name>/example/index.faces
    I don't really know how to follow the link change from .html to .faces because the login step will not be kept for the next step. If i'm trying to access http://<name>/example/index.faces i'll get the error page with something predefined like "the app is not accessible".
    Can you help me with a solution or a workaround? Is it a way to do this?
