Database connectivity error
  • karanpreetsingh1990
    • Apr 2020
    • 16
    I'm new to zabbix and have been trying to get an instance up and running with a remote MySql database but have hit a wall.
    The connection suceeds from the backend and it's able to connect and start the zabbix-server but the setup on the frontend fails with the error:
    • Error setting auto commit.
    I've tried everything but can't seem to get it fixed. I would appreciate any help that can be provided for the same.
    Thanks,
    Karan
    • Apr 2020
    • 16
    After much research I was able to resolve this. Turns out that even thought the Database user was set up to use the mysql_native_plugin, the default in the instance was still the newer scheme that doesn't seem to be working with the frontend or to be more specific php. I got the instance configuration changed to make the mysql_native_plugin. Once I got that changed and the instance restarted, this started working as expected.
