Monitoring connection from Zabbix Agent to external server
  • duyth4
    • Apr 2020
    Hello all, I am new to Zabbix and I have a problem like below :
    I have installed an Zabbix Server, let's call it Server A
    A Window Server 2016 PC, which have installed Zabbix Agent, we call it Agent B
    An external server, which we cant install or do anything about it, named Server C.
    Server A can connect and monitor Agent B as usual, but cannot connect to server C.
    Agent B is running an app which establish a TCP connection to server C through a specific port.
    The question is : Can I monitor the connection from Agent B to server C using simple check like "net.tcp.service" ?
    If not, are there any possible solution ?
    Sorry for my bad English but thank you all for your concern and hope you all are well and healthy during these unsettling times.
  • c1support
    • Apr 2020
    • 47
    Are you able (i.e. allowed to) to install a Zabbix Proxy on Server B (maybe inside a Hyper-V Virtual Machine, possibly based on Zabbix Appliance)?
    See also https://en.wikipedia.org/wiki/Zabbix => High level architecture in chapter "Features"
    • Hamardaban
      • May 2019
      • 2714
      Another clever way https://share.zabbix.com/operating-s...-windows-agent
      • c1support
        • Apr 2020
        • 47
        Originally posted by Hamardaban
        Sounds really interesting, particularly if you are certain that the target is not moving (i.e. scope will remain restricted to ping-monitoring only). Thanks for sharing!
        • Hamardaban
          • May 2019
          • 2714
          To duytha4
          What is the problem with using the standard net.tcp.service[service,<ip>,<port>] (or net.tcp.service.perf) in your case??
          Try net. tcp. service[tcp,<server_c_ip>,<server_c_tcpport>]
          • Semiadmin
            • Oct 2014
            • 1626
            There are simple check key net.tcp.service and agent check with the same key. In this case, you need an agent check.
            • duyth4
              • Apr 2020
              Thanks everyone for help I am nearly done for my monitoring server.
              But now I have a question is : "Does net.tcp.service is a telnet check ?"
              Because I have a huge amount of host and I really dont want it to telnet to my server at the same time.
              • Hamardaban
                • May 2019
                • 2714
                • duyth4
                  • Apr 2020
                  So basically it will create a connection session to my server. Will it closed immediately after success check or it will stay there forever ?
                  • Hamardaban
                    Hamardaban commented
                    Closed.
                    Perhaps you should study the operation of this TCP/IP protocols in more detail?
                • Aminam
                  • Nov 2020
                  Hello!
                  do you find a solution at last?
                  does these suggestions work?
                  i'm having your problem unfortunately !
