Is it possible to create network map automatically ?
  • gurlinks
    • Mar 2020
    • 11
    I'm using Zabbix 4.4 to monitor my network which has more than a thousand devices. It's difficult to create a manual network map.
    Is there any way to create an automatic network map to visualize my network?
  • c1support
    • Apr 2020
    • 47
    This would be an awesome feature for larger networks.
    I am no expert, but I have not yet stumbled accross anything like this out of the box.
    I could think of two ways:
    1. Zabbix API (https://www.zabbix.com/documentation...nce/map/create) - pretty confident this will work, although not tried
    2. Templates - here I am not experienced enough to evaluate if this is even possible
    Maintaining such a large network, you might be interested in these lovely maps symbols: https://share.zabbix.com/zabbix-tool...icons-for-maps (also not yet used myself, only came accross this while writing this post)
    Besides: There is a dedicated area of the forum for larger environments: https://www.zabbix.com/forum/zabbix-...e-environments
    • patrickdenis
      • May 2020
      • 18
      Yes it is possible
      • maashiq
        maashiq commented
        Any idea how we can achieve that ?
    • Jartsa
      • Jan 2021
      How can we do that? I supposed it is possible to automatically search devices too from network and add them to hosts list? I have just started with this and added approx. 100 switches by hand just to see what this looks like before I dive into this more.
      • c1support
        • Apr 2020
        • 47
        Not tested, just an idea how I would approach this issue:
        - create initalMap.xml, containing a small number of representative hosts (including labels, links, etc)
        - manually export the map from Zabbix into initialMap.xml
        - understand the relevant segments of initialMap.XML-structure
        - segment initialMap.xml into two files: skeleton.xml (containing the map without hosts) and oneHost.xml (will be used later)
        - using any scripting language (e.g. Python)
        - retrieve host info via Zabbix API
        - for each host, insert a modified oneHost.xml into skeleton.xml => resulting in finalMap.xml
        - Import finalMap.xml via Zabbix API
        If anybody knows of a more elegant approach, I would be interested to learn about it!
        • PackElend
          • Jul 2022
          Originally posted by patrickdenis
          Yes it is possible
          would like to know as well
          • jtnfoley
            • Mar 2022
            • 83
            Subscribing and a Google links paste dump for my own future reference. Searching for "cdp lldp zabbix map" (without the quotes) since CDP and LLDP are the main protocols that should be useful in mapping networks.
            https://www.reddit.com/r/zabbix/comm...mment/gle2lhl/
            Network Administration Visualized. Contribute to Uninett/nav development by creating an account on GitHub.
            https://en.wikipedia.org/wiki/Netdisco
