Only trigger alert after consecutive failures (using str)
  • yossarianuk
    • Apr 2020
    Hi.
    I would like an alert to trigger only after a report of a failure occurs multiple consecutive times
    I have a script which sends, via zabbix-sender to the zabbix server string values.
    At present I have this trigger (as an example)
    {TPL_IPA_Server:ipa.ntpd.service.str(STOPPED)}=1
    Which works fine to alert you when we have 1 fail.
    I want it to trigger only after X (say 3) fails in a row - how is this possible ?
    I have tried these triggers and all just trigger after 1 fail.
    {TPL_IPA_Server:ipa.ntpd.service.str[B]([/B]STOPPED,#3[B])[/B]}=1
    {{TPL_IPA_Server:ipa.ntpd.service.regexp(STOPPED,#3)}=1
    I have seen these threads however none have helped - i.e the trigger alerts after only 1 fail..
    Can anyone help me ?
    Cheers
  • yossarianuk
    • Apr 2020
    I ended up asking in the #Zabbix irc room and got an answer
    Which was
    {TPL_IPA_Server:ipa.ntpd.service.count(#3,STOPPED)}=3
