Automatically disable and enable dependent hosts
  • Arul
    • May 2020
    • 23
    Helllo,
    in zabbix 4.0 how to automatically disable and enable dependent hosts on network switch during flapping network issues. To avoid alert from the host triggers for dependent issues.
    Thanks.
  • tim.mooney
    • Dec 2012
    • 1436
    You don't need to fully disable the hosts, you just need to set up dependencies between the triggers on your hosts and the trigger for the network device(s).
    See: https://www.zabbix.com/documentation...s/dependencies
    • Arul
      • May 2020
      • 23
      Thanks Tim Mooney.
      • gofree
        • Dec 2017
        • 400
        even better - setu global correlation via tags - will pay off later as your environment grows
